Author Topic: Paint Dab on leaf spring ubolt  (Read 5597 times)
Offline ChrisV289
« on: February 20, 2016, 07:55:44 PM »
So I pulled my rear end out to detail before this years MCA show in Reno and soaked my u bolts and spring plate on the passenger side in evaporust. Didn't find any markings on the plate but did find I think one on the u bolts. Can't tell what color though (pink or white maybe?). Anyone know what it should be and if they will be on all four and what the orientation of the dab on each u bolt? Like will the inner ones be in the front or back or both same for the outer u bolt. I attached one pic. The paint dab unfortunately wiped off :(
2009 V6 Mustang Coupe
Re: Paint Dab on leaf spring ubolt
« Reply #1 on: February 20, 2016, 09:28:09 PM »
Pink on all 4.
Offline ChrisV289
« Reply #2 on: February 21, 2016, 02:08:38 PM »
Thanks Charles, will the pink be towards the front or the rear of the car?
« Reply #3 on: February 21, 2016, 11:52:51 PM »
Seen it towards the rear, but not sure if all like that.
Offline tomtri66
  • Bronze Level Subscriber
« Reply #4 on: March 23, 2016, 05:38:47 PM »
My Jan 1966 Metuchen Built Hardtop had pink as well.  On the top though.
MCA# 78748 Adirondack Shelby Mustang Club
66 Metuchen HT Sprint 200 Package B
6T07T194XXX   65A       Y       22     20A     ?        2       6
                    BODY  COLOR  TRIM  DATE  DSO  AXLE  TRANS
C/O    762
4        A20     6T07T194XXX
65A       Y        22
Online outlawincorporated
  • Kangaroo Herder
« Reply #5 on: March 24, 2016, 11:20:12 AM »
+1 to the above pink paint dabs as well for both a 66 NJ February and March built car as well.
regards
PHILL BERESFORD
MELBOURNE.
AUSTRALIA.
Offline GT500KR
  • Charlie Ping
« Reply #6 on: March 28, 2016, 09:43:16 AM »
   Would the mark have been to indicate for use with 8" or 9" housings, or to indicate that the u bolts had been tightened?
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
65 Ivy Green Coupe 4SPD
68 Candy Apple Red GT500KR 4SPD FB
70 Grabber Blue Boss 429
86 JalapeƱo Red GT  5SPD
91 Emerald Green Saleen Conv. 5SPD
03 Sonic Blue Cobra Conv.
07 Black GT500 Cp
« Reply #7 on: March 28, 2016, 05:10:10 PM »
Most likely the size - don't believe its related to tightening.
Offline tomtri66
« Reply #8 on: March 29, 2016, 09:22:20 AM »
I can tell you that I found my pink marks on my original u-bolts from my sprint 6 cylinder rear end.  so, not sure if it is size.
« Last Edit: March 29, 2016, 09:25:54 AM by tomtri66 »
C/O    762
4        A20     6T07T194XXX
65A       Y        22
« Reply #9 on: March 29, 2016, 04:16:29 PM »
Remember that other car models were built on the same line so not always referring to just Mustang applications. Since all the reports so far are from Mustangs and are similar color the size idea seems to fit so far since they all used the same rearend shock plate I believe
Offline ChrisV289
« Reply #10 on: March 29, 2016, 06:23:50 PM »
Location seems to be different.  Mine were towards the bottom, tomtri66's were at the top.  Maybe depends on year and plant??
« Reply #11 on: March 29, 2016, 07:05:44 PM »
Or maybe just the worker who was applying the mark that day ;)
Offline tomtri66
« Reply #12 on: March 31, 2016, 12:04:01 AM »
Maybe I misunderstood.  Were you referring to the axle size (ie. 7-1/4", 8" or 9") or the size of the axle tube?
Tom
C/O    762
4        A20     6T07T194XXX
65A       Y        22
« Reply #13 on: March 31, 2016, 01:44:41 AM »
If so then I must have not been clear or written my post well.
Was referring to the size of the U clamp. Since all use the same rearend shock plate they should all be the same (honestly have not checked the parts book to confirm)
Offline tomtri66
« Reply #14 on: March 31, 2016, 02:05:06 AM »
ahhh...  Got it, thanks Jeff!
Tom
C/O    762
4        A20     6T07T194XXX
65A       Y        22
