Author Topic: Correct Floor Plan Plug - 70 NJ  (Read 2431 times)
Offline joe747
« on: June 13, 2010, 11:32:23 PM »
i have a few different plugs , but i am not sure which one is correct for the floor pan drain hole .does anyone have a pic of this plug
thanks
« Last Edit: June 14, 2010, 09:56:32 PM by J_Speegle »
Re: CORRECT FLOOR DRAIN PLUG
« Reply #1 on: June 14, 2010, 09:55:56 PM »
Looks like they used the dished/ concaved style at NJ in 70  (from your earlier post)
0T02G115584
0Txxx1220xx
Offline joe747
Re: Correct Floor Plan Plug - 70 NJ
« Reply #2 on: June 15, 2010, 08:24:06 PM »
sorry Jeff
 i meant the ones just above the floor support . all the suppliers list them in their catologs but they are the one for the seat holes
« Reply #3 on: June 15, 2010, 11:50:36 PM »
Sorry Joe but (its me ) can't figure out the ones that your referring to "just above the floor support"   ???
Offline joe747
« Reply #4 on: June 16, 2010, 05:23:40 PM »
there is a hole in the inside of the car at the floor centered aboce the front frame /floor support .it is on both sides . i have treid all kinds of rubber plus and none will fit ,it is 1 inch dia.
« Reply #5 on: June 16, 2010, 11:04:08 PM »
there is a hole in the inside of the car at the floor centered above the front frame /floor support .it is on both sides . i have treid all kinds of rubber plus and none will fit ,it is 1 inch dia.
Ok - the upper hole that held the car to the skid/dolly during the body assembly. Not all of the plugs are reproduced so you may have to find and use an original. Or settle on a smaller size with some strip chalking around it
