Author Topic: 1966 Master Cylinder  (Read 2045 times)
Offline Building 3
« on: April 25, 2016, 10:13:13 AM »
Can anyone tell me if either of these are the correct master cylinder for a 1966 Dearborn built Mustang? Thanks
Re: 1966 Master Cylinder
« Reply #1 on: April 25, 2016, 11:16:47 AM »
Originals were usually Bendix, if you flip them over, there will be markings.  I've seen date codes cast into the bottom and the 'B' logo for Bendix.
Offline Building 3
« Reply #2 on: April 25, 2016, 06:55:24 PM »
No such luck. The booster has no markings or logos and the master says: Made in USA    45466
In addition to looking for the B and the date code should I be looking for one with the boss that was formerly used for the stop light switch on the top of the housing, on the bottom, or both. In looking through piles of these I have seen all three variations. I am pretty sure the manual brake cars had the boss only on top, but how about the Power Brake system. That's what I am looking for. Thank you.
« Reply #3 on: April 25, 2016, 08:58:35 PM »
Doesn't look like an OEM piece.  The boss for the brake switch carried over into production, some with no hole and some with a hole and plug.
Offline Building 3
« Reply #4 on: April 27, 2016, 08:28:34 AM »
Thank you. I will keep looking.
Offline 66RavenGTCoupe
« Reply #5 on: April 28, 2016, 03:56:15 AM »
Please correct me if I am wrong guys but I think that this may be what you are looking for
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
« Reply #6 on: April 28, 2016, 11:23:46 AM »
That's a good example.  The Bendix logo can vary in size.  That one has a julian casting date.
Offline Building 3
« Reply #7 on: April 29, 2016, 12:23:47 PM »
Charles/RavenGTCoupe: Thanks for the excellent photos.  They help out a lot. Can I assume that for 1966, the unused stop light switch boss is always on the bottom for a power brake car and on the top for a manual brake car? So I need to find one on the bottom for my power brake car. Is there another way to tell the difference? Is the bore size indicated anywhere on the casting? 1" for manual and 7/8" for power? Thanks.
Offline Building 3
« Reply #8 on: May 11, 2016, 10:52:42 AM »
In trying to track down an original 1966 Power Brake Master Cylinder I need to look for the "B" for Bendix. Also, should I be looking for only ones with the unused stoplight switch boss on the top or doesn't it matter if it's on the top or the bottom?  Will the bore size of 7/8" or 1" always be indicated on the casting? Thank You.
