Author Topic: 67 C4 automatic transmission gear shift lever replacement  (Read 728 times)
Offline socalgt
« on: June 01, 2016, 12:07:21 AM »
I need to replace the gear shift lever(that comes out of the transmission). ( The lever is broken off of the outer shaft)  I read an article indicating that with the pan off, leaving the valve body on, the nut can be loosened with a hammer and long punch, and the outer shaft removed, the nut held in place and a new outer shaft installed and secured with the nut.  Any one have any experience with this method?  Sounds good to me, as  opposed to removing the valve body.
Offline socalgt
Re: 67 C4 automatic transmission gear shift lever replacement
« Reply #1 on: June 06, 2016, 07:50:31 PM »
I will go ahead and answer my own question....no, the nut cannot be removed with the valve body installed...there was just no way.  After removing the valve body,  A 7/8" box wrench worked fine.
« Last Edit: June 06, 2016, 08:52:09 PM by socalgt »
