Author Topic: 69 Mustang Side Cowl Insulation  (Read 2689 times)
Offline VikingNJ
« on: May 02, 2017, 10:18:07 AM »
To All,
I have seen in some photos over the years there appears to be insulation material that exists on side cowl panel above and behind side vent panels. However, I have not seen a insulation mounted only photos anywhere. I believe insulation was used on Mach 1, boss shelby and cougars models.  My car was only left with shreds of insulation left.
Thanks.
Nils
Offline Armond
  • Silver Level Subscriber
    • D'Agostini Restorations.com
Re: 69 Mustang Side Cowl Insulation
« Reply #1 on: May 02, 2017, 10:23:12 PM »
I just went thru my photo's of a all original 69 Shelby and there appears never to have the side cowl insulation like I have seen on earlier years.  And I don't recall it being used in 69/70.  None on the Boss 429 I have here also.   But I guess it may have had it at some point.
MCA#31064
« Reply #2 on: May 03, 2017, 12:40:38 PM »
it falls apart very easy behind plastic kickpanels
Offline VikingNJ
« Reply #3 on: May 03, 2017, 03:40:25 PM »
Ed,
So there was insulation on side cowl panels. I am curious what it looked like and how it looked installed prior to other stuff installed over it.
I have attached (i hope)a photo I recently saw of the heater assy with view from center of car towards right side and it appears to have insulation material like the dash insulation pad sandwiched between side cowl panel and dash assy.
Nils
« Last Edit: May 03, 2017, 03:46:16 PM by VikingNJ »
« Reply #4 on: May 03, 2017, 04:44:51 PM »
Ed,
Not really the same stuff or covering the same area as the stuff that was used on earlier cars. and since the vent was there only about 50% of the kick panel would have had it behind the panel. Instead some versions are much like trunk and under carpet underlayment and unlike the stuff used under the cowl from side to side. Other plants appear to have used a product similar to what was used on the body behind the sail panels
Will see if I have a pictures of one that is complete or another angle
Does appear that the material differed depending on where and when the car was assembled.  So can you provide that or we'll have a bunch of pictures that don't relate? ;)
« Last Edit: May 03, 2017, 04:49:15 PM by J_Speegle »
Offline Brian Conway
« Reply #5 on: May 03, 2017, 06:36:12 PM »
The picture above showing a bit of insulation above the vent panel is of my car.  Taken through the glove box opening.  FWIW no insulation on the left side behind above the vent panel and behind the Parking Brake assembly.  Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
« Reply #6 on: May 03, 2017, 09:43:14 PM »
Also therewas  a plastic lined insulation pad ( on 69 deluxe interior anyway) above the heaterbox glued to the bottom of cowl panel that always falls apart . Someone needs to repo  both these pads as they usually cant be saved& used over.
Offline VikingNJ
« Reply #7 on: May 08, 2017, 02:23:01 PM »
Ed,
correct...does anyone have photos of that insulation pad that is glued to bottom of cowl. Mine was all gone in pieces...
« Reply #8 on: May 08, 2017, 03:53:15 PM »
Ed,
The trash bag liner with the hole pattern (bottom surface once installed) with the fiberglass insulation. Will look - thing I've got at least one picture where the stuff hasn't turned to dust yet :)
« Last Edit: May 08, 2017, 04:53:09 PM by J_Speegle »
« Reply #9 on: May 08, 2017, 04:55:46 PM »
Here is a 69 San Jose example
Not sure if it would stay in one piece if someone tried to remove one
Offline VikingNJ
« Reply #10 on: May 12, 2017, 12:06:03 PM »
Jeff,
I tried years ago but it came off in pieces...
« Reply #11 on: May 14, 2017, 11:46:24 PM »
someone needs to make that part as every car would need one
