Author Topic: 289 Z Casting Number  (Read 2752 times)
Offline MK1_Oz
« on: June 22, 2017, 08:32:21 PM »
Good Morning,
Been reading this forum for a while but never joined (sorry).  I have a question that my fellow Mustang lovers on the Australian Mustang forum (mustang.org.au) cannot answer and I am hoping somebody over there can.
I have a 289 block that has a casting number of Z5AE-6015-A.  What is this from and when was it made?  It doesn't follow the usual Ford numbering system.
It has 289 cast into the valley but does NOT say anything about Mexico in there.  It has 2T441 stamped into the bellhousing mouting flange.  Although I did not measure them, the mains caps look quite narrow so I doubt they are the wider HiPo style ones.
I have spent hours researching via the interweb but have only found TWO other references to this casting number!!
Re: 289 Z Casting Number
« Reply #1 on: June 23, 2017, 12:44:15 AM »
How did you determine it was a 289?
Another item is that the date code format is backwards from 60's style built block.
Might it from a 80's or 90's Ford vehicle will look some more and others will offer their experiences
« Last Edit: June 23, 2017, 12:47:59 AM by J_Speegle »
Offline MK1_Oz
« Reply #2 on: June 23, 2017, 12:50:24 AM »
289 cast into the lifter valley.  could well be a later engine.  No idea what it came out of or when.
Offline C6ZZGT
« Reply #3 on: June 23, 2017, 12:31:37 PM »
How about the eng assm date stamp on the lh front ?
Brian
66 GT Coupe 6R07A143871 owned since 1983
40+ yr parts man , over 25 with Ford.
« Reply #4 on: June 23, 2017, 12:48:03 PM »
Perhaps the block was cast in the country of Mexico?
« Reply #5 on: June 23, 2017, 03:11:13 PM »
All the ones I've seen so far have had HECHO- EN MEXICO in the lifter valley. Guess that he looked for that given his original post. Though later engines (if they even cast them in Mexico) might have different castings
Offline MK1_Oz
« Reply #6 on: June 24, 2017, 04:54:46 AM »
Tis a true mystery.  The whole internet and only 3 blocks with this number...
Offline Ted67
« Reply #7 on: August 05, 2019, 06:49:17 PM »
I also have a block with this casting
« Reply #8 on: August 05, 2019, 07:28:52 PM »
Does it also have the lifer valley castings mentioned above?
At one point some were selling these as Hipo blocks due to the main caps - unsuspecting individuals that likely didn't even look at anything else.
BTW welcome to the site - hope you find the information and support helpful in your restoration projects
« Last Edit: August 05, 2019, 07:35:24 PM by J_Speegle »
Offline preaction
« Reply #9 on: August 06, 2019, 05:20:47 PM »
Z was the model line designation for mustang maybe a sleeply Monday morning at foundry  ::)
Offline Scode67FB
« Reply #10 on: August 07, 2019, 04:58:00 AM »
It sounds like the block is an Australian casting. The Aussie system is nothing like the US system. The casting date on it is in a different format from US production. Like most of the world outside the US, the casting date is shown in Month/Day/Year. It probably is different from anything here. It probably has the hole for the clutch linkage on the RIGHT side of the block. Who knows what else could be different.
« Reply #11 on: August 07, 2019, 02:01:08 PM »
Various post on the Interweb and here:
http://www.concoursmustang.com/forum/index.php?topic=6058.15
suggest it's a Mexican 289. I have a Mexican 302, so I know what those look like and this shares only a few of those traits. However, the Mexican 302 has a totally different casting number.
« Reply #12 on: August 07, 2019, 02:52:45 PM »
It sounds like the block is an Australian casting..........
Do you have a picture/example?  Guess you've seen a fair number of them
BTW Welcome to the site. Hope you find it helpful in your restoration projects and needs.
