Author Topic: 1970 Boss 302 carpet  (Read 7668 times)
Offline HDAshmore
« on: July 01, 2017, 12:35:48 AM »
Is there any difference in the carpet for a 1970 Sportsroof and a 1970 Boss 302 with Décor group interior.  The color is Black for both.
Dan
Re: 1970 Boss 302 carpet
« Reply #1 on: July 01, 2017, 03:13:17 PM »
Believe originally they were one in the same. Have owned other decor interior body types and that was the way they were.  Would post pictures but in general most owners like to hide them under mats :(
Offline rockhouse66
« Reply #2 on: July 02, 2017, 07:01:17 PM »
FYI, no toe pad.
'66 GT FB
Offline 7mustangs
« Reply #3 on: November 12, 2020, 12:24:41 AM »
So, I bought mew carpet for my 70 Boss and the front part ends on the floor pan just below where the raised panel for the seat is. My other 69 fastback has the carpet overlapping under the seat frame. Which is correct? Also, is the toe pad that smaller vinyl piece on the side of the shifter hump? Thanks
« Reply #4 on: November 12, 2020, 09:54:21 PM »
So, I bought mew carpet for my 70 Boss and the front part ends on the floor pan just below where the raised panel for the seat is. My other 69 fastback has the carpet overlapping under the seat frame.Which is correct?
Here is the best I can do from the pictures  I have. Hope they help
Would suggest you try and adjust it as far back as possible (given other edges that still need to be where they need to be) to provide a lip for the rear section to cover
Yes if your reproduction has a pad on the drives side to the right of the  accelerator pedal that is a toe pad and originally your car would not have one. You and order reproduction without the toe pad (you really should not have to ask) but so many cars have reproduction carpet in their car they are replacing owners assume that the pad is original
Toe pad example from an earlier Mustangs
Original standard carpet for 1970 Mustangs
« Last Edit: November 12, 2020, 10:39:59 PM by J_Speegle »
Offline Mike_B_SVT
« Reply #5 on: November 18, 2020, 02:47:18 PM »
Just as some additional info, my '70 Cougar (October '69, Dearborn plant) original carpet, the front section also ends right at the front edge of the seat riser.  I've been wondering if it's supposed to be that way or not.
My understanding is the carpet is the same between Cougar and Mustang.
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
Offline 7mustangs
« Reply #6 on: November 27, 2020, 11:32:01 AM »
 Does anyone know where to get the correct carpet?
« Reply #7 on: November 27, 2020, 03:57:31 PM »
Don't know that you really have many options. Might only be two providers of molded carpet out there selling through the normal outlets. You will need to request one made without the toe pad and once you receive it get it out and inspect it - don't just put in on the shelf for later. Sometimes they will forget or ignore your request  or not line up the carpet in the mold so that the channels do not go straight across but at an angle. Have had to send a few back over the years
Offline myboss
« Reply #8 on: November 11, 2021, 05:47:36 PM »
  Can a toe pad be successfully removed with out messing up the carpet ???
Dan
« Reply #9 on: November 11, 2021, 10:29:38 PM »
Good question. Have not tried with the newer carpets that are available. More recently (over the last decade) have just ordered the carper without the toe pad. I take it that you've already purchased and received your carpet
Offline rockhouse66
« Reply #10 on: November 12, 2021, 08:25:56 AM »
Dan
I did so on my Grande but it was a 20 year old repro carpet and the toe pad was sewn.  A razor blade and in 5 minutes it was out.  It is possible (likely?) that the new repro stuff has a glued on toe pad.  If so, I think you are stuck (see what I did there?  ;) ).
'66 GT FB
Offline myboss
« Reply #11 on: November 12, 2021, 10:01:41 AM »
   No ,  like rockhouse I purchased it 20 years ago and I do believe it is sown on . Its in the car at this time don't know if I can do it in the car with a razor blade like suggested or will have to remove it to do it .
thanks
Dan in phoenix
Offline rockhouse66
« Reply #12 on: November 12, 2021, 12:11:40 PM »
I did this easily in the car.
'66 GT FB
Offline 1970shelbyguy
« Reply #13 on: June 23, 2022, 04:30:49 PM »
seeing there's discussion on the carpet  - how about the  high beam switch  grommet - believe  no but confirm   and the little cap on top ?  thanks  david    dec  69  Metuchen  boss 302
1970 gt500  grabber blue  june/69     1970  boss 302  metuchen  dec/69
« Reply #14 on: June 23, 2022, 06:35:11 PM »
Easy - not grommet (that was something borrowed from GM carpet by the early carpet reproducers)  and no switch cap on a 70 Boss
