Author Topic: R code 1972 Mustang  (Read 2564 times)
Offline sjrdcr
R code 1972 Mustang
« on: September 07, 2017, 09:42:53 PM »
Back in the day I owned a 1971 Boss 351 Mustang, which were only available with the 4 speed transmission. In 1972, the R code 351 engine was still being offered, the difference from the 1971 Boss being flat top pistons and open chamber heads to lower compression to 9 to 1, but still retaining a solid lifer cam. I was always under the impression that this 1972 R code version was also only available with the 4 speed. Earlier today a 1972 Mach 1 went across the block at Mecum Dallas which was claimed to be an R-code 351 with automatic trans. Ant thoughts on this? Please note that I am not referring to the Q code 351 CJ version which was also available in 1972 with both the 4 speed and the C6 automatic.
Re: R code 1972 Mustang
« Reply #1 on: September 07, 2017, 11:00:22 PM »
Kevin Marti's By The Numbers says that the 1972 R code only came with the 5 transmission (4 speed manual)---no automagics.  Only 398 of them to boot!
Offline sjrdcr
« Reply #2 on: September 08, 2017, 09:37:51 AM »
The car was lot number T140 sold on Thursday. A couple things under the hood are definitely incorrect for an R code. The intake should be aluminum, the valve covers should also be aluminum, the air cleaner is not correct, and although there is a power steering oil cooler present I don't see an engine oil cooler which should have been present since the R code cars all came with a 3.91 traction lok. A perfect example of buyer beware and to research any vehicle that you intend to buy. I suspect that this is actually a Q code car with a doctored vin # or an R code that had it's drivetrain swapped out at some point.
Offline 66kcoupe
« Reply #3 on: September 09, 2017, 06:00:57 PM »
I was there today to look at the car. Listed as a no sale at $14,100. It looks to have a '70 M code motor in it, all visible codes on the motor were D0OE. Originally a light pewter metallic car, couldn't find any of the 4 speed stuff left in it. Rear pumpkin tag missing. Really rusty underneath.
« Last Edit: September 09, 2017, 06:04:17 PM by 66kcoupe »
1966 Mustang Hipo Coupe, in the family since new (unrestored)
1991 Mustang LX 5.0 Notchback (daily driver)
Offline sjrdcr
« Reply #4 on: September 10, 2017, 06:10:06 PM »
So it did actually have an R engine code on both the dash and door tags?
« Reply #5 on: September 10, 2017, 11:10:30 PM »
Unfortunately both can be faked and the dash board one goes with the forward dash pad panel. Not sure what Ford was thinking with that designed.
Bought a 71 429CJ once that someone had stolen and simply swapped the dash pad and that panel from a 351 car. Police towed it as abandoned off the streets of Oakland CA and they never realized it had been swapped or stolen.  ::)  Ended up in a salvage auction when I found it  I wonder if the sequential "hidden| numbers match the title and Marti. Well not really only if I was considering buying or looking at the car for a buyer.
Offline 66kcoupe
« Reply #6 on: September 11, 2017, 12:56:51 PM »
Yes it did have both dash and door tag, both showed R code and matching VIN, hidden parts of the car showed the light pewter metallic paint, I think it was real just missing all the good parts
Offline TUMBLEPORT SVT
« Reply #7 on: March 26, 2018, 12:14:04 PM »
     1971 Boss 351 and 1972 HO did not have a factory oil cooler .
