Author Topic: Fuse Box Lettering - How did they do it?  (Read 4416 times)
Re: Fuse Box Lettering - How did they do it?
« Reply #15 on: October 26, 2017, 07:12:49 PM »
Do note that these Deco pens are available in oil based or acrylic formula.
Oil would require a thinner -- acrylic is water based.
My wife has an extensive collection of paint brushes and paints for various hobbies.
I had dozens of brushes to pick from as well as dozens of paints.
I used a small hobby (like model car) brush and an acrylic paint.
If you have to buy something these look like a good deal. If I looked in a different drawer I might have found these!
Offline suskeenwiske
  • 214-347-3628
« Reply #16 on: December 28, 2017, 02:25:44 PM »
A few things to note:
1) Oil Based works better on Chromed Metal Surfaces, such as Heater Control Knobs.
2) Be careful how much pressure you use to apply the paint. It prevents premature wear to the tip of the Marker and provides greater uniformity.
3) Sometimes it takes a couple of applications to get the results you need.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
« Reply #17 on: December 28, 2017, 02:49:11 PM »
I played around with the ink process, and found that the majority of the early fuse boxes that I have have raised letters, not recessed letters.  I guess there were at least two suppliers during this time.
Offline mtinkham
  • That'll be easy
« Reply #18 on: January 29, 2018, 01:45:36 PM »
Is it possible that the factory did the marking and embossed lettering all in one operation....like hot stamping? It would be fast and could be automated. We do hot stamping here at work, but it is typically done on a raised surface. But, I would think that with the right set of dies, the operation could do both...just throwing it out there for consideration...
