Author Topic: 67 p/s pump stampings  (Read 1431 times)
Offline 22mafeja
« on: October 20, 2017, 08:37:12 AM »
My pump is a reman without tag. The question is as always ford or trw pump . It has some signs stamped on the cast surface close
to the pump shaft. These are clearly P.40.PSO.14 and beneath not so clear AF 3 where the A and F are touching each other.
Is this telling you anything?
Ralf
Re: 67 p/s pump stampings
« Reply #1 on: October 20, 2017, 02:49:02 PM »
Maybe a picture of the area, if possible would help.  Guessing this is not on the seal (the markings)
Offline 22mafeja
« Reply #2 on: October 20, 2017, 04:54:58 PM »
Here are the pictures  but they are hardly any good..
Ralf
« Reply #3 on: October 20, 2017, 09:54:52 PM »
No (can be faint or a poor casting) FoMoCo in the rectangle to the left (rotation) from those marks?
Offline 22mafeja
« Reply #4 on: October 21, 2017, 08:38:09 AM »
No , nothing more .
Thank you anyway Jeff
Ralf
« Reply #5 on: October 21, 2017, 03:27:13 PM »
Ralf
The TRW casting is identified with a "W" and the Ford Thompson with the FOMOCO trademark. With that said  I see in picture 2 what appears to be a poor looking "W" identification mark.
« Reply #6 on: October 21, 2017, 04:15:54 PM »
No , nothing more .
Not done yet .........
Since it visually lacks that marking then it's likely TRW - Bob is seeing that trademark in your pictures apparently so I think you have two votes  :)
Offline 22mafeja
« Reply #7 on: October 21, 2017, 04:33:04 PM »
If it is a Trw pump if it hasn`t Fomoco on then we have a winner. I will go for semi gloss black colour then.
Ralf
Offline 22mafeja
« Reply #8 on: October 21, 2017, 04:52:46 PM »
And now I am sure it is a Trw. I happened to see a picture of a reman on Ebay where the marks on my pump were clearly
visible and where the Trw was also visible.
Ralf
« Reply #9 on: October 23, 2017, 12:30:34 PM »
Ralf, I would find a tag, it also serves as a washer for assembly.
« Reply #10 on: October 23, 2017, 04:17:15 PM »
+1 . Although finding a tag with a exact application stamped into it is desirable If you can't find the exact tag then find a tag regardless of application and paint it along with the pump . You can also just turn it around so the black side is facing out. Once painted it is extremely hard if not impossible to read the stamping on the tag once painted anyway. Regardless something is better then nothing in this situation. ;)
Offline 22mafeja
« Reply #11 on: October 27, 2017, 06:12:19 AM »
Thanks Bob for that idea. My homemade tag is on the pump now next to a also homemade support bracket  ::)
Ralf
