Author Topic: 1965/66 Mustang upper and lower control arms  (Read 4223 times)
Offline 65fastbk
« on: January 20, 2018, 02:34:16 AM »
Hi,
Looking for some quality upper and lower control arms for a driver.  I saw some rare parts ones, the scott drake ones.  Not sure if its better to buy one of these or find someone to rebuild my originals.  What is everyone using?
Thx!
Mark
Offline ChrisV289
Re: 1965/66 Mustang upper and lower control arms
« Reply #1 on: January 20, 2018, 09:52:00 AM »
I had Anghel Restorations redo mine. Turned out great.
2009 V6 Mustang Coupe
« Reply #2 on: January 22, 2018, 10:37:51 AM »
The RP ones that I have seen were for a 67-68 and the shape on the sides was incorrect.  I used an original control arm to mark out the correct side dimensions and ground the RP ones down.  They actually came out really nice.  The ball joint was a cheap replacement, bought some MOOG ones and used correct boots and had Marcus rivet them on.  The only benefit of the RP ones is that you start with clean, pit-free metal, they will require additional work to make them look decent.
« Reply #3 on: January 22, 2018, 06:19:52 PM »
Wonder what they would want for just the bare a arms.  For the guys that can't find nice unrusty originals. I liked the that they had the stretch and holder (when shaping) marks that go away when some blast or clean their originals
« Reply #4 on: January 22, 2018, 09:05:28 PM »
What is RP for the uninitiated (like dumb ol' me...)?
Offline FXguy
    • Early 64 June K Convertible Restoration
« Reply #5 on: January 22, 2018, 09:37:07 PM »
I suspect they are talking about "Rare Parts" the supplier.
-Scott
Scott McMullen
64 1/2 K Code Specialist, pre/early production historian, collector, and restorer.
"I'm absolutely sure of one thing, and that is I don't know everything...there is always something new to be discovered...and that's where the fun is."
Offline FXguy
« Reply #6 on: January 22, 2018, 09:38:22 PM »
+1 Marcus does nice work.
-Scott
Scott McMullen
« Reply #7 on: January 23, 2018, 01:38:23 AM »
+1 Originally a company that started making niche parts that were out of production for allot of odd brands, they started doing the rivets and stamping for a few of us, then moved into wider markets selling directly then on to and including reproduction parts for other vendors. Owners have been the same since they left their earlier job and set up the shop next the the alignment shop they started with and the rest is history.  Guys running the shop and the engineers have changed over the years.
Offline evantugby
« Reply #8 on: January 25, 2018, 10:33:38 PM »
What price did you get for the rebuild on your upper and lower control arms?  I was just quoted at $800 for the upper and $800 for the lower by Anghel Restorations.
Offline ChrisV289
« Reply #9 on: January 26, 2018, 10:52:04 AM »
That's about right. Take a look at what he was able to do to mine. He even got the jacking tabs back up after being crushed
http://www.concoursmustang.com/forum/index.php?topic=15308.15
Offline Chris
« Reply #10 on: January 28, 2018, 01:42:33 PM »
So the Scott Drake upper and lower control arms are not completely correct (pics attached)?
64 1/2 Poppy Red Convertible, 260V8 auto, 19 June 64
« Reply #11 on: January 28, 2018, 01:47:10 PM »
nope. rivits, paint line among other things.
Offline Chris
« Reply #12 on: January 28, 2018, 01:59:17 PM »
I’m replacing mine but can’t afford the restoration route ($800 each). So the rivits are the incorect style? Are they supposed to be the waffle pattern? Any more specifics on the issues with the Scott Drakes? I’ve not seen anything closer to originals.
I’m replacing my control arms and tie rods. My steering is sloppy and the car has the squeeks, tired of spraying everything with lithium grease:).
« Reply #13 on: January 28, 2018, 02:46:06 PM »
A small book could be written on the differences. If you are going the economy route the Drake would be a good compromise IMO . There is a lot worse out there on the market. However do not have any illusion that the Drake parts are very much like assemblyline. They will only fool the uninformed. They have a lot of "tells" as mentioned before.
Offline 65fastbk
« Reply #14 on: January 29, 2018, 06:15:09 PM »
What would be a good quality aftermarket upper and lower control arm to get if one had to.  I know the Rare parts one do not look factory, but they are made in the US i thing, not sure of the Scott drake ones?
