Author Topic: N.S.S. Wire tag  (Read 1673 times)
Offline rrenz
N.S.S. Wire tag
« on: February 18, 2018, 08:27:28 PM »
It doesn't appear that anyone reproduces the Wire Tag for the neutral safety switch? Has anyone tried to make their own or have a scan of an original by any chance?
Ryan
1966 C Code NJ Springtime Yellow
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
Offline ChrisV289
Re: N.S.S. Wire tag
« Reply #1 on: February 18, 2018, 10:19:42 PM »
I was wondering the same thing. It is green.
2009 V6 Mustang Coupe
Re: N.S.S. Wire tag
« Reply #2 on: February 18, 2018, 11:44:47 PM »
This one?  If I remember right, has a C5PF marking or something like that.
Re: N.S.S. Wire tag
« Reply #3 on: February 18, 2018, 11:47:58 PM »
Another pic found on the web...
Offline ChrisV289
Re: N.S.S. Wire tag
« Reply #4 on: February 18, 2018, 11:56:53 PM »
My tag is green though and the one connector is black, not blue.
« Last Edit: February 18, 2018, 11:59:37 PM by ChrisV289 »
Re: N.S.S. Wire tag
« Reply #5 on: February 19, 2018, 12:22:13 AM »
Yours looks like a later Ford replacement.  Probably has Motorcraft markings on the switch body.  The plugs should be blue/red, to match the ones on the harness going through the firewall.
Offline ChrisV289
Re: N.S.S. Wire tag
« Reply #6 on: February 19, 2018, 09:43:40 AM »
Has a fomoco logo on it.  Also got a better picture of the label.
Re: N.S.S. Wire tag
« Reply #7 on: February 19, 2018, 05:53:24 PM »
'Ford' on the wire label wouldn't be period-correct.  I still believe it's a later Ford replacement.  Maybe for later years, 67-up.
Offline rrenz
Re: N.S.S. Wire tag
« Reply #8 on: February 19, 2018, 06:45:50 PM »
From what I've seen they are green. Im surprised with the amount of tags that are reproduced this one has been left out.
Ryan
C-4 Automatic
Build Date Jan 21st
Re: N.S.S. Wire tag
« Reply #9 on: February 19, 2018, 07:32:34 PM »
The example I gave is a low mileage June '65 Dearborn car that has not been restored.
Attaching another pic of a low mileage unrestored '66 Dearborn car.  I don't have the VIN or scheduled date.  Probably can find more.
Guess I would ask if anyone has examples of original cars with a green tag?
Offline rrenz
Re: N.S.S. Wire tag
« Reply #10 on: February 19, 2018, 07:44:35 PM »
I just came across this thread which supports the white tag which could be easily replicated at home. Replacements I've seen are green. Unsure of originals.
http://www.concoursmustang.com/forum/index.php?topic=758.msg3824;topicseen#msg3824
« Last Edit: February 19, 2018, 07:53:07 PM by rrenz »
Ryan
C-4 Automatic
Build Date Jan 21st
Re: N.S.S. Wire tag
« Reply #11 on: February 19, 2018, 07:54:56 PM »
4 more... I'm sure Jeff could come up with additional examples.
Re: N.S.S. Wire tag
« Reply #12 on: February 20, 2018, 04:22:55 PM »
Could (have been watching) but it appears you have more than enough samples to support the pattern seen.
Doing these at home is fairly easy - still takes a fair amount of time to draw all the fonts (since your stock ones will not normally match) do the graphics and get everything aligned. Then the media you print on can be a challenge depending on the color used.
Re: N.S.S. Wire tag
« Reply #13 on: February 20, 2018, 07:43:19 PM »
Figured you were enjoying someone else stepping up with pics like you normally do  ;) ;) :D
Offline outlawincorporated
  • Kangaroo Herder
Re: N.S.S. Wire tag
« Reply #14 on: February 21, 2018, 06:04:07 AM »
sounds like Charles is cutting your grass there Jeff............
can confirm from my experience white label as well on all my unrestored cars as well.
regards.
PHILL BERESFORD
MELBOURNE.
AUSTRALIA.
