Author Topic: Grille Rivets  (Read 3412 times)
Offline rrenz
Grille Rivets
« on: February 28, 2018, 08:32:27 PM »
Restoring my grille and I'm ready to put my new tube rivets in. Where is everyone obtaining the Tool or Die to compress these? I was originally thinking I would try to turn a tool on my lathe but if there is a good source for a tool I may just purchase one. Thanks.
Ryan
1966 C Code NJ Springtime Yellow
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
Re: Grille Rivets
« Reply #1 on: February 28, 2018, 08:52:25 PM »
Click on this link, check page 2, scroll down to find the tool I made for doing these rivets on my 67.
http://www.concoursmustang.com/forum/index.php?topic=13842.15#lastPost
I bought the dies here if they are still available: http://www.ebay.com/itm/181482608898?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I imagine there are less expensive dies out there but this is what I used.
« Last Edit: February 28, 2018, 08:55:48 PM by 67gtasanjose »
Offline rrenz
Re: Grille Rivets
« Reply #2 on: February 28, 2018, 09:28:32 PM »
Thanks. I haven’t run into that thread yet. Looks like I’ll go this route. After rechroming the horse and corral what’s another 40 bucks at this point I guess.
Ryan
C-4 Automatic
Build Date Jan 21st
Re: Grille Rivets
« Reply #3 on: March 01, 2018, 12:32:00 AM »
I've used these guys for years - jay cee sales and rivet co. https://rivetsinstock.com/
Here's the tool - https://www.rivetsonline.com/solid-semi-tubular-rivet-tools/hand-rivet-squeezers
It was cheaper way back when.
I used it to reattach 64-66 ash tray slide rails after I had the ash trays replated. I made fixtures to attach the face plate using a Harbor Freight one ton arbor press and the dies used from the hand rivet tool. See below.
It also is good for 64-65 grill end pieces.
Re: Grille Rivets
« Reply #4 on: March 01, 2018, 05:14:35 AM »
That is where I was at at the time. Jim's idea is good too. The actual rivet squeezer tool is not too expensive either and I am sure like any tool, it will get used again here or there for other things.
I wish to add a detail I discovered on the tool I made (mentioned later in the thread link I posted), I added a 1/4" ball bearing into the threaded press side of the C-clamp to prevent the die from spinning during the "squeeze". A spinning die could (read as WILL) damage any painted or plated surface.
Offline rrenz
Re: Grille Rivets
« Reply #5 on: March 01, 2018, 08:26:07 PM »
Thanks for the help. I like both ideas since I already have a shop press. a cheap c clamp from harbor freight would work well also.Ill have to order the die and see what I can come up with.
Ryan
C-4 Automatic
Build Date Jan 21st
Offline must69
Re: Grille Rivets
« Reply #6 on: June 13, 2018, 12:25:46 AM »
jwc66k, I tried the link you provided for the rivets.  Any idea what they actually call them? I could not find any reference to tube rivets on their site.
Thanks.
Phil
Offline Skyway65
  • Gold Level Subscriber
Re: Grille Rivets
« Reply #7 on: June 13, 2018, 07:26:48 AM »
Thanks.
Phil
I used these on my '65 grill a couple of years ago--they are nearly an identical match to the originals.
Gary Schweitzer
MCA #00181
Traverse City, MI
Re: Grille Rivets
« Reply #8 on: June 13, 2018, 02:35:55 PM »
Gary,
That's them.
Offline must69
Re: Grille Rivets
« Reply #9 on: June 18, 2018, 02:33:01 PM »
Thanks for all the info on the grille rivets.  I got the dies, but the rivets in black are no longer available, so aluminum will have to do and that paint or phosphate.
Thanks.
Phil
Offline Skyway65
Re: Grille Rivets
« Reply #10 on: June 21, 2018, 08:55:14 AM »
Good luck with the project.  Post some pictures when you're done. :)
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline must69
Re: Grille Rivets
« Reply #11 on: June 27, 2018, 04:17:19 PM »
I decided to get the rivet compressor, and in five minutes it is done. I had purchased an aftermarket replacement grille.  That one is going back.
Re: Grille Rivets
« Reply #12 on: June 27, 2018, 04:33:40 PM »
"The right tool for the right job". My father used to say that a lot.
Offline must69
Re: Grille Rivets
« Reply #13 on: June 27, 2018, 05:00:31 PM »
Jim, I tried to rig up something to compress them, but I needed two extra hands.  Just was not worth my time. For $62. On Amazon it was worth it.  I have a saying to, if I need a tool, don’t rent or borrow, buy it!  Your dad was absolutely right!
Phil
Re: Grille Rivets
« Reply #14 on: June 27, 2018, 07:35:20 PM »
Phil
Phil,
Take a look the two pictures in reply 3 (mine). They show fixtures I made up to install rivets in 64-66 ashtray side rails and face plates using the rivet dies associated with the rivet hand tool. I use the same Harbor Freight press on license plate light assemblies, and bolt removal and installation from coil spring saddles (that was for Jason - morsel - last weekend). I made three more fixtures today, from a couple of 1/2 inch conduit fittings and a piece of 3/4 inch conduit, to press out and then in, the lamp sockets. The conduit fitting were notched to clear the license plate wire.
(Psst - the arbor press can be used to crack walnuts if necessary.)
