Author Topic: Ford Thompson Pump  (Read 6713 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Re: Ford Thompson Pump
« Reply #15 on: October 07, 2010, 07:35:54 AM »
Thanks a lot Chris.
Is this what I'm seeing?
Crank Pulley - 3 grooves  (I know my 66 pulley P/N is different from yours though)
Water Pump Pulley  -  2 grooves   (I know my 66 pulley P/N is different from yours though)
Most rear groove  =  crank + water pump + alternator
Middle groove      =   crank + water pump + power steering pump
Front groove       =   crank + A/C + A/C idler pulley
Is this correct?
66 Metuch Conv
Nightmist, Std Blu Int
Offline ChrisV289
« Reply #16 on: October 07, 2010, 11:00:30 AM »
The crank pully I have has three grooves.  The most rear groove has the alternator belt.  The middle groove contains the power steering belt and the front groove has the AC belt.
The water pump pully has two grooves;  The rear groove has the alternator belt and the front groove has the power steering belt.
The AC belt is only on the crank pully and the AC idler pully.
Does that help?
2009 V6 Mustang Coupe
Offline bryancobb
  • 2009 Ridn' Around
« Reply #17 on: October 07, 2010, 01:45:20 PM »
Yep  ;)  Thanks a lot!
66 Metuch Conv
