Author Topic: 1967-1968 tilt wheel rag joint  (Read 1534 times)
Offline Hipo giddyup
« on: April 01, 2018, 02:01:03 PM »
Hi all, I recently found this tilt wheel rag joint in a box of Mustang parts at a local swap meet. My question is, what is the best way to refurbish this? Were the metal portions PO?? I was thinking of soaking it in evaporust but I was worried that the rag joint material might swell or be damaged??? Any tips?
Re: 1967-1968 tilt wheel rag joint
« Reply #1 on: April 01, 2018, 02:12:51 PM »
Portions are PO and others bare steel . It will be fine in the evaporust. The joint material  is very tough and doesn't swell in all of the times I have done it.
« Reply #2 on: April 01, 2018, 09:44:47 PM »
As Bob wrote it will clean up well since it appears to be in good shape. The different shades will likely show through once its soaked. If not the contrast can be increased by restoring (using gun blueing repair fluid, small brush and so on) to the cast sections.
Remember to coat it to protect it from rusting once done.
« Reply #3 on: April 01, 2018, 10:11:30 PM »
Thanks for the reply guys. I’ll post a few pics when I’m done as an example for others viewing this.
« Reply #4 on: April 09, 2018, 09:55:55 PM »
As a follow-up I just wanted to post a few pics of the rag joint after being soaked in evaporust. Turned out pretty nice. It looks like there are a few white paint marks on the rag joint? And on the edge of the rag joint also looks what appears to be red paint or marker? Not sure what this could be or it might be nothing.?
« Reply #5 on: April 09, 2018, 10:23:47 PM »
It looks nice. I have not seen paint on them but I have not seen on a unrestored car.
« Reply #6 on: April 09, 2018, 11:46:32 PM »
 On the second pic you can see white splotches towards the center of the rag joint material. Right near the cast piece. The last picture shows what looks to be red paint or red marker on the outside edge. Not sure what this could be? Maybe nothing?
Offline Coralsnake
« Reply #7 on: April 09, 2018, 11:52:56 PM »
I believe that rubber is recycled, just like the rubber on the exhaust hangers....
« Reply #8 on: April 10, 2018, 12:11:09 AM »
That's possible, but from what? You can see white sidewall remains on exhaust hangers, and the rubber is twisted. This rubber is flat.
Online midlife
« Reply #9 on: April 10, 2018, 07:56:38 AM »
It's obvious: it's from a flat tire!
I kill myself sometimes!
« Reply #10 on: April 10, 2018, 12:23:28 PM »
Only on the bottom.
(Straight lines are three for a dollar.)
