Author Topic: 1964-1/2 Tie Rods Refinishing  (Read 1473 times)
Offline must69
« on: April 06, 2018, 06:02:40 PM »
I read somewhere that OE tie rods can be rebuilt.  If this is possible, does anyone know who does this?
« Last Edit: April 15, 2020, 04:46:52 PM by J_Speegle »
Re: 1964-1/2 Tie Rods Refinishing
« Reply #1 on: April 06, 2018, 06:48:12 PM »
I haven't heard of anyone rebuilding them. Guess you might be able if the internal in reproduction or aftermarket interchange with originals and you had the tools to remove the caps and reinstall them again. Most any business would be concerned about liability and would likely remind the owner/builder that they were not for road use  ::)
If you can't find originals in good shape or NOS ones guess it would not be something that could not be attempted  at home dependign on your access to tools
« Last Edit: April 15, 2020, 04:47:41 PM by J_Speegle »
Offline ChrisV289
Re: 1964-1/2 Tie Rods Rebuilt
« Reply #2 on: April 06, 2018, 06:49:05 PM »
I think Marcus can a Anghel Restorations
2009 V6 Mustang Coupe
« Reply #3 on: April 07, 2018, 08:03:26 PM »
They are not rebuilt. Usable originals are cosmetically restored.
Offline evantugby
« Reply #4 on: April 14, 2018, 10:31:54 AM »
+1
I specifically asked Marcus to rebuild mine and he cannot. I sent Fred Ballard one set of my tie rods and he was unable to remove the cap too.
These tie rods were very common, as I understand all V8s shared the same tie rods depending upon if they were manual steering vs power steering.
I was able to locate good usable tie rods from a guy named Mike in Austin Texas who has many mustang parts. Let me know if you need his contact info.
« Last Edit: April 15, 2020, 04:47:31 PM by J_Speegle »
« Reply #5 on: April 14, 2018, 06:39:54 PM »
The 65-66 V8 tie rods are not all interchangeable between PS and manual steering cars.
Maybe this scan will help illustrate (taken from a final printing of the MPC)  the different application and parts.  There was a campaign/recall related to tie rod ends at least for the PS cars in 66  if I recall the date correctly. Have not be able to figure out or find documentation of the problem or issue but have a campaign "kit"  of all four in a single box with the campaign label on the main box
« Last Edit: April 14, 2018, 07:03:48 PM by J_Speegle »
Offline evantugby
« Reply #6 on: April 14, 2020, 06:02:57 PM »
Hello,
I can refinish your tie rods as long as you don’t need the shaft bolt replaced. Here are some pictures of restored tie rods next to a media blaster unfinished tie rod.  Last picture is just pulled off of car.
Here are a few pictures of mine.
« Last Edit: April 15, 2020, 04:47:21 PM by J_Speegle »
Offline OldGuy
« Reply #7 on: April 14, 2020, 09:18:17 PM »
Hello,
I can rebuild your tie rods as long as you don’t need the shaft bolt replaced. Here are some pictures of restored tie rods next to a media blaster unfinished tie rod.  Last picture is just pulled off of car.
There is a REAL difference "rebuilding" verses "refinishing". I think that you probably meant to say you can "refinish" the tie rods. Correct me if I'm mistaken and please briefly describe what you replace if you actually "rebuild" these units.
Frank
« Reply #8 on: April 14, 2020, 10:48:28 PM »
They can't be rebuilt, only cosmetically restored.  I'll only do this on tie rods that are still tight.  The outers usually wear the worst, maybe due to the upright position and possibility of holding water/moisture over time (once the boots start failing).
Offline evantugby
« Reply #9 on: April 14, 2020, 11:50:30 PM »
Frank
I changed my verbiage to “refinished” since the bolt shaft was not replaced.
« Last Edit: April 15, 2020, 04:47:07 PM by J_Speegle »
