Author Topic: correct distributor 1970 351C  (Read 1622 times)
Offline SCJSTU
« on: October 29, 2018, 01:43:46 PM »
late build June 1970 351C....auto, ac Dearborn convertible
would it have an Autolite or Motorcraft?
casting numbers?
2004 Mach 1 Azure Blue
Re: correct distributor 1970 351C
« Reply #1 on: October 29, 2018, 04:10:58 PM »
Easy one first - would be cast with the Autolite script in the housing. Motorcraft didn't come into use for a few more years.
Offline cobrajet_carl
« Reply #2 on: October 29, 2018, 07:19:00 PM »
Probably D0OF-Z but late 70 AT usually got the distributor modulator system don't know if that makes any difference
« Last Edit: October 30, 2018, 12:14:05 PM by cobrajet_carl »
Carl
70 and 71 Dearborn mach Is
Offline 70cj428
« Reply #3 on: October 29, 2018, 09:30:49 PM »
M code or H code ?
My Late Dearborn M code Mach1 (Auto, AC) has a D0OF-Z Distributor, I'm sure it's original.
Hope this helps, John
 EDIT... I took my comment about the 2bbl Distributor out cause I'm not sure it's right. The 70 Shop manual specifies an AO suffix but everything else I read says otherwise .....
« Last Edit: October 30, 2018, 02:48:04 PM by 70cj428 »
Offline SCJSTU
« Reply #4 on: October 29, 2018, 09:54:06 PM »
M code or H code ?
My Late Dearborn M code Mach1 (Auto, AC) has a D0OF-Z Distributor, I'm sure it's original. I think an H code (Auto) would be a D0AF-AO
M code car
« Reply #5 on: October 30, 2018, 12:27:25 AM »
casting numbers?
Did you look in the Forum's Library?
Offline SCJSTU
« Reply #6 on: October 30, 2018, 12:45:37 PM »
Thanks Jim, never knew to look there great info...
assume the last column is for a Motorcraft service replacement and the factory originals are all Autolite on the chart?
