Author Topic: Windshield Heater Duct Fasteners  (Read 1137 times)
Offline 1970 Snake
« on: November 19, 2018, 12:59:03 PM »
It looks like there are three (3) special flat headed plastic type fasteners that hold the windshield heater duct to the body/dash sheet metal, and I have misplaced or lost mine. Can anyone advise if these are reproduced and where to get them?
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Re: Windshield Heater Duct Fasteners
« Reply #1 on: November 19, 2018, 05:32:11 PM »
If you have at least one example I would got the local auto paint supplier or even parts store and compare it to all of the small packages of body trim hardware to find one that matches the diameter and length needed.  Could do the same by using measurements taken or estimated by comparing both parts and the total length needed to hold them together
Here are some examples of what is available There are likely 100's of different types, styles and designes
Offline 69GT350H
« Reply #2 on: November 19, 2018, 09:26:26 PM »
Might these be them?
Offline boss167961
« Reply #3 on: November 19, 2018, 10:15:06 PM »
Yes they are and NPD sells quite good repro sets in the correct finishes.
Martin
« Reply #4 on: November 19, 2018, 10:21:27 PM »
Martin
Have to wait and see since the OP described his as plastic.
Yes the metal studs and retainers have been available for years
Offline 1970 Snake
« Reply #5 on: November 20, 2018, 02:27:50 AM »
Thanks for the input guys, sorry Jeff I didn't mean to mislead you, I am not exactly sure what they are made of and just assumed plastic because of the single plastic clip I do have which pins it to the heater box, but could very well be metal as I do not have an original and my pictures do not show a complete fastener only what you see in the pic I attached. the NPD ones could possibly be correct, but I would not know and is why I asked the question. The attached is the best picture I have of the attaching fastener. I have to assume they are metal now as it looks like that's what the majority is saying. Thanks all.
« Last Edit: November 20, 2018, 03:02:40 AM by 1970 Snake »
Offline geo302b
« Reply #6 on: November 20, 2018, 08:21:28 AM »
Metal ones, stud down
« Reply #7 on: November 21, 2018, 12:04:57 AM »
Thanks for the input guys, sorry Jeff I didn't mean to mislead you, ..................
No problem - just working with what I've been given and no longer have a 70 I can go out and check plus didn't want to assume that 69's were the same ;)
Main thing is you getting the correct answers :)
