Author Topic: 67 GT 390 heater elbow  (Read 1464 times)
Offline TLea
« on: January 05, 2019, 09:40:23 AM »
What style intake manifold heater hose elbow did a June 67 390 car use?  How about water pump nipple? Was intake elbow painted? Thanks in advance
« Last Edit: January 06, 2019, 10:50:30 AM by TLea »
Offline DTruitt
Re: 67 GT 390 heater elbow
« Reply #1 on: January 05, 2019, 05:29:42 PM »
Confused! Are you asking about a 67 or 68?
Danny
MCA Gold Card Judge
Offline TLea
« Reply #2 on: January 06, 2019, 10:51:04 AM »
Sorry 67
Offline DTruitt
« Reply #3 on: January 06, 2019, 11:36:47 AM »
Tim,
There are a couple pictures in this thread Jeff posted.  It may help.
http://www.concoursmustang.com/forum/index.php?topic=17981.0
Danny
MCA Gold Card Judge
« Reply #4 on: January 06, 2019, 05:01:59 PM »
Need to go look at another complete unrestored 67 380 San Jose car this week if it stops raining and get some pictures. Hopefully its still at the shop.
Offline TLea
« Reply #5 on: January 06, 2019, 08:02:12 PM »
Those are helpful. Looks like manifold fitting was in when painted?
Offline DTruitt
« Reply #6 on: January 06, 2019, 08:16:42 PM »
This thread has some clearer pictures of the intake fitting. It appears the intake fitting was in place before paint.
http://www.concoursmustang.com/forum/index.php?topic=17894.0
Danny
MCA Gold Card Judge
Offline TLea
« Reply #7 on: January 06, 2019, 11:03:51 PM »
That one has straight water pump nipple. Other car has 45 adapter?
« Reply #8 on: January 06, 2019, 11:19:44 PM »
The green NJ example has had the water pump fitting replaced likely due to rusting out. The one in the first (67 SJ) example with the odd fitting then the add on straight section is the original and discussed later in the green NJ examples thread.
Close up. Obvious to see someone in the past was in the area of the fitting with a rattle can so we don't know if the fitting was painted with the engine by using this one example
« Last Edit: January 06, 2019, 11:26:51 PM by J_Speegle »
Offline TLea
« Reply #9 on: January 07, 2019, 12:08:17 AM »
 Thanks. Judging from all the blue paint and other areas it doesn’t belong I’m gonna say the painting of the nipple is suspect
« Reply #10 on: January 07, 2019, 06:14:59 PM »
Without a doubt.
Looking at everything that is the correct/original fitting and it was added after (for some unknown reason) after the engine was painted. Haven't found any signs of them using a slip over mask like other applciations or parts
Offline rocnhrse
« Reply #11 on: December 28, 2020, 09:58:15 PM »
After  reading  all the information  I can find on the site  I am now confused  about  which  nipple  would  be correct  on a April 67 San Jose  built thermactor  390 with  no air, is it straight up,or off on a angle towards the passenger side, painted od natural, over or under the top rad hose,just  want to get it right  the first time
« Last Edit: December 29, 2020, 12:16:34 AM by J_Speegle »
67 mustang  GTA  S code fastback  San Jose  April 67
« Reply #12 on: December 28, 2020, 10:19:08 PM »
It is two piece. a angle fitting and a straight fitting. Once mounted it sticks straight up. It was used through very early 68 production before changing to only the one piece fitting that when mounted points at a angle.Mansfield Mustang sells them .I don't know about the others.Regardless of which style they were added after the engine was painted so no paint on them.
« Reply #13 on: December 29, 2020, 12:19:14 AM »
Picture of the item Bob is referring to in his post above. Same as posted  (now that these are merged) above
Plenty of evidence that it, along with other parts in the picture, got a coat of paint during a rattle can refreshing by a PO
Angle of the available picture does not show the angle fitting very well.  Radiator and such got in the way
Going to merge this thread and another to keep things together and improve/update the older one
« Last Edit: December 29, 2020, 12:27:40 AM by J_Speegle »
