Author Topic: 64 1/2 power steering set up suit air con car  (Read 827 times)
Offline national-mustangs
« on: January 24, 2019, 12:54:43 AM »
hey guys, im chasing a 64 1/2 power steering set up suit air con car that mounts to the apron,
appreciate any leads,
thanks
« Last Edit: January 24, 2019, 12:56:57 AM by national-mustangs »
5F07F172293
Offline KDunne
Re: 64 1/2 power steering set up suit air con car
« Reply #1 on: January 24, 2019, 02:10:56 PM »
Lots to collect.....in addition to the PS set up, you'll need a new water pump, crank, generator pulleys....
Not my auction......   https://www.ebay.com/itm/1964-1965-Ford-Mustang-Power-Steering-Kit-C5ZZ03A635-A-Fastback-OEM-1089/392103967089?hash=item5b4b37b971:g:vhsAAOSwP65bdY0d:rk:11:pf:0
« Last Edit: January 24, 2019, 02:18:40 PM by Teke »
« Reply #2 on: January 24, 2019, 05:45:23 PM »
thanks for that, would you have pics or part numbers of the other required parts?
5F07F172293
Offline KDunne
« Reply #3 on: January 25, 2019, 10:54:03 AM »
I don't have any pictures, however I recall a unique idler pulley for the 64 1/2's.  Not 100% sure on that but I'm sure others on this board are way more knowledgeable in this area...Good Luck with your search
« Last Edit: January 25, 2019, 10:56:13 AM by Teke »
« Reply #4 on: January 27, 2019, 07:06:23 AM »
Here is some information from various MPCs
The first picture is from the 60-68 MPC with a nice table of the kits available.  A lot of activity for 65, even more than change prone 67.
The remaining pictures are from the 65 MPC
Note that this represents what Ford would do in a service (aftermarket) situation, and may not represent what was done at any particular assembly plant at the time your car was built.  But it is a decent starting point.
« Reply #5 on: January 27, 2019, 12:45:30 PM »
True. The "pitfall" of the MPC is revealed.
Offline national mustangs
« Reply #6 on: March 11, 2019, 07:34:00 AM »
Hey guys, any further parts or air con set up available for 64 1/2 with power steer?
Offline Hazmat
« Reply #7 on: April 15, 2019, 11:45:33 PM »
I've been trying to find some off the same parts myself. I came across a couple Mustang distributors that said they carried parts that were the same part numbers as Classic Auto Air. Knowing CAA no longer carries the parts, I questioned the other distributors' availablity, and they said they're no longer available and that they'd remove them from their website. I noticed one removed them finally so no one else would get their hopes up like I did when I saw them listed.
