Author Topic: 70 rear side marker lights  (Read 2284 times)
Offline Rcodenewf
« on: February 05, 2019, 03:09:05 PM »
Anyone have a pic of how the little metal bracket fits on the rear side marker lights? On another forum it was suggested that they don't belong on there but they were definitely on there upon disassembly over 8 years ago....i just can't recall how they were installed.
The hole in the center of the bracket will not allow the pigtail socket to pass through it.
Open to opinions and suggestions. thanks...John
Re: 70 rear side marker lights
« Reply #1 on: February 05, 2019, 10:14:37 PM »
You didn't include when and where your car was built so we're left to guess. Picked a collection across the plants and months.
Not sure what metal bracket your referring to or what your have since you didn't provide a pictures. Hope one of the following helps you in your search ++
0F100xxx
0F123xxx
0F166xxx
0T1138xx
0T145xx
0R1xxxx
Stud/ lugage protectors fell off of allot of them :)
« Reply #2 on: February 06, 2019, 12:33:55 AM »
Yup, the pictures reflect what is in the 1970 Mustang Electrical Assembly Manual (AM0033 pg 41) right on down to the stud protectors.
« Reply #3 on: February 06, 2019, 10:59:28 AM »
There is a metal strap on white plastic just under the black plastic outer holder on the later 70 wire  black plug push-in type socket VS early type white twist in type wire socket.  I think the black socket type shows up after jan 70 & uses the  wide black tape covering the socket or is that a plant change. Look at jeffs last photo as u can see the silver metal strap under the black plastic & where the tape was before being peeled off.
« Last Edit: February 06, 2019, 11:02:17 AM by specialed »
« Reply #4 on: February 06, 2019, 04:13:30 PM »
A grounding strap Ed?  The metal strap your referring to. Since its a two wire hook up maybe it for something else.
Would have helped if the OP would have included plant and production period/date ;)
Offline Rcodenewf
« Reply #5 on: February 06, 2019, 06:49:43 PM »
Sorry for the lack of info fellas. The car is an October 70 Dearborn convert 0F03H car.
I did take these off but for the life of me i can't recall the sequence.
I do appreciate all the input.....John
« Reply #6 on: February 08, 2019, 02:08:43 AM »
Doesnt the metal strap flip the other way & the early white plug twist in but the black plug just pushin to the metal strap hole so thats how it holds in place.
Offline Rcodenewf
« Reply #7 on: February 16, 2019, 12:56:00 AM »
Specialed: Yep, i flipped it over and it fits flush with the opening in the lens. My dilemma is that i removed these from this car way back and upon looking at the rear harness it has the twist in sockets.??? Or else i have another rear harness here somewhere with the push in sockets which would make sense for sure.
I'll keep looking...thanks for the response.
..John
Offline carm
« Reply #8 on: February 16, 2019, 08:58:00 AM »
Was this shield only installed on 1970 Mustangs??
1969 GT350 convertible grabber orange
Auto
Built: April 21,1969. Dearborn
« Reply #9 on: February 16, 2019, 10:01:08 AM »
no torinos mavericks etc also used the black shield but have different eng #s because of angle changes.
Offline carm
« Reply #10 on: February 16, 2019, 12:07:12 PM »
What I meant to ask was, Was this shield used 69 Mustangs also?
Auto
« Reply #11 on: February 16, 2019, 12:42:56 PM »
According to the 70 Mustang Electrical Assembly Manual, it was a 1970 Mustang designed part. According to the 1969 Mustang Electrical Assembly Manual, it's a different design.
Are you looking for alternate sources?
Offline carm
« Reply #12 on: February 16, 2019, 04:43:55 PM »
It’s been so long since I’ve taken the car apart that I’ve forgotten how the rear markers were installed. Did my car also have a similar bracket, I’ll have to look through the parts...🤣
Auto
« Reply #13 on: February 16, 2019, 05:58:12 PM »
No except possibly for some really late 69 Dearborn cars for some reason (another subject) . From some of the cars in the unrestored picture section of the site ;)
Offline carm
« Reply #14 on: February 19, 2019, 06:05:35 PM »
Thanks, that looks more familiar to me, since my car is a Dearborn ,April 21, 1969.
My friends' Metuchen 1970 Boss 302, has them however. In this picture we can see the part number, DOZB-15A439A.
« Last Edit: February 19, 2019, 06:11:44 PM by carm »
Auto
