Author Topic: WTB ~Distributor Primary Wire, Yellow Boot  (Read 1057 times)
« on: February 13, 2019, 05:17:23 AM »
Looking for a restorable or nice distributor Primary lead with a push-on Yellow Boot.
If you have a 'lead' on one or suggestions on getting one made up (Alloy Metal?), let me know.
Thanks in 'advance'  :D
Re: WTB ~Distributor Primary Wire, Yellow Boot
« Reply #1 on: February 13, 2019, 09:34:36 AM »
If you can't find one, the more common white one can be dyed/painted yellow.
Offline ChrisV289
« Reply #2 on: February 13, 2019, 03:55:04 PM »
Was 65 the same connector or different? Looked through the library and not a good picture of the connector
2009 V6 Mustang Coupe
« Reply #3 on: February 13, 2019, 04:36:56 PM »
Since this is in the wanted section, you should probably ask the question in a new post in the 65-66 area.
Offline ChrisV289
« Reply #4 on: February 13, 2019, 04:45:47 PM »
Understood but this is sitting on my blue fastback and if it is not correct than you would be in luck.
« Reply #5 on: February 13, 2019, 04:50:19 PM »
http://www.concoursmustang.com/forum/index.php?topic=18657.0
Reply #5     Labeled ENG-1 Through ENG-3 Ignore the other repaired wire and the nuts  ::)
« Reply #6 on: February 13, 2019, 05:13:01 PM »
BINGO!
Sad part is I just this noon hour today discovered that I need a Distributor too! I will likely temporarily use the one I have now (with a new wire) but it isn't even the correct one for my car! I just read the engineering numbers today and both that and the date code have it as a 68 302 Distributor so I'll start a new hunt for another distributor as well. These cars...ALWAYS something!
« Last Edit: February 13, 2019, 05:18:59 PM by 67gtasanjose »
Offline ChrisV289
« Reply #7 on: February 13, 2019, 09:53:34 PM »
So do you still need this wire?
« Reply #8 on: February 14, 2019, 04:34:06 AM »
I expect I do. Not likely I'll happen across a correct distributor with a good, correct primary lead. I'll pm you.
