Author Topic: 1968 GT 390 (San Jose) Odd Engine block markings inside block  (Read 642 times)
Offline bullitt68
Has anyone seen these markings inside the block before. My engine builder says they were drawn on at the factory to tell the line what pistons to put in the block. FYI this is an original bore block never messed with until now. Any help would be appreciated thanks
Mike
Re: 1968 GT 390 (San Jose) Odd Engine block markings inside block
« Reply #1 on: March 13, 2019, 10:07:54 PM »
pics would be nice....
Offline bullitt68
« Reply #2 on: March 13, 2019, 10:11:30 PM »
Sorry. Not sure why, but for some reason I am not able to upload the photos. Have been trying for a while on different devices and no luck so far
Mike
Offline bullitt68
« Reply #3 on: March 13, 2019, 10:15:12 PM »
Looks like the photo just showed up mysteriously!
Mike
Offline 70cj428
« Reply #4 on: March 13, 2019, 10:33:37 PM »
Not uncommon, I'm pretty certain the numbers correspond to bore size so they could select fit the pistons ....
Offline bullitt68
« Reply #5 on: March 13, 2019, 10:42:31 PM »
Thanks John
Mike
« Reply #6 on: March 14, 2019, 09:56:49 AM »
Correct. The pistons were select fitted by the assembler. The bores were inspected after machining and marked so that all the assembler had to do was select the proper size piston / rod assembly to go in each hole.
Offline bullitt68
« Reply #7 on: March 14, 2019, 10:14:26 AM »
Thanks for confirming Royce
Mike
