Author Topic: 67 v. 68 interior rear quarter fiberglass panels  (Read 1348 times)
« on: March 29, 2019, 10:45:19 PM »
Larry Z. just finished my interior rear fiberglass panels and sent me a pic. They look fantastic.
The conversation turned to a set of panels he has and he noted that his has notches molded into both sides where the seat rests when folded flat.
Mine are on only the passenger side.
I've never noticed this before, so he rattled off the numbers on one of his which were:
C7zb-6331486-bw
C8zb-6331486-aw
so his have both years molded into the back.
Mine are
c7zb-6331070-bw
c7zb-6331486-bw
and
c7zb-6331071-bw
c7zb-6331487-bw
I gather mine are correct . . .
Online jwc66k
Re: 67 v. 68 interior rear quarter fiberglass panels
« Reply #1 on: March 30, 2019, 04:52:58 PM »
Ford used different part numbers to represent different stages of that parts process, in this case a fiberglass forming number and a finished item number. The C7ZB-6331486-BW (and 487-BW) are the finished item numbers, which are called out on the assembly drawings (with an appropriate painted finish designation). The C7AB-6331070-BW may be the "as formed", "pre-holes drilled" version. Instead of a paper tag to identify each, both numbers were embossed into the part.
Note: For 67 service, the MPC calls out a C7ZZ- and a C8ZZ- part number for RH/LH panels. For 68 service, both sides are C8ZZ-.
« Reply #2 on: March 30, 2019, 05:07:09 PM »
Yeah, I get that.
But out in the field is the single sided passenger-only notch version correct (for most of the year) and that the notches being on both sides is predominately 68?
On edit -- add a pic with the "notch" in the center of the pic.
« Last Edit: March 30, 2019, 05:10:41 PM by Bossbill »
« Reply #3 on: March 30, 2019, 06:10:04 PM »
Looking at my pictures yes the addition of the clearance "notch" on the drivers side was an addition made for 68 production fastbacks
« Reply #4 on: March 30, 2019, 06:20:19 PM »
In the conversation with Larry he wondered if I had the right panel.
This is one of those things I've never heard about.
Thanks, Jeff.
Offline bullitt68
« Reply #5 on: April 03, 2019, 06:32:44 AM »
C7zb-6331486-bw
C8zb-6331486-aw
Mine are
c7zb-6331070-bw
c7zb-6331486-bw
and
c7zb-6331071-bw
c7zb-6331487-bw
They Look great. Do you know what paint he used by chance?
Mike
Offline celticray
« Reply #6 on: November 20, 2022, 12:40:15 AM »
Hi
I see that Larry Z restored your interior quarterpanels.   Is he still doing this?   How would I contact him.   They really came out great
Tom
« Reply #8 on: November 20, 2022, 11:41:40 AM »
Since he is "in the biz" it's probably ok to list his number publicly.
I'll scramble it a bit to avoid his number from being hit with spam.
586-nine zero 4- zero zero zero 7
Unless you are local the freight will be brutal.
Offline celticray
« Reply #9 on: November 20, 2022, 01:26:01 PM »
Thanks really appreciate it!
« Reply #10 on: November 20, 2022, 05:03:32 PM »
Just a reminder there were two versions of the 67 panels with-out and the later with the cut out around the fold down latch/non-fold down upper seat support
I3 in the 67 San Jose Running Changes thread and
https://www.concoursmustang.com/forum/index.php?topic=13555.0
