Author Topic: CLOSED -- 67 (ONLY) 4 bolt Upper Control Arms with good pivot threads  (Read 1092 times)
I've decided to try DDS restorations trick of stacking or squeezing in the threads.
Thanks to all that replied.
Ok, I'm not having much luck on the 67 (ONLY) 4 bolt UCA front.
This is a two part wanted ad.
What are people asking for their FoMoCo, unrusted UCAs with verified decent pivot threads?
Even if you don't have them currently I'm wondering what the market is asking.
If someone has a couple for sale PM me here or bossbill (the at sign) comcast (add the dot net bit). Gouges near the BJ ok.
« Last Edit: June 17, 2019, 05:31:53 PM by Bossbill »
Re: 67 (ONLY) 4 bolt Upper Control Arms with good pivot threads
« Reply #1 on: June 11, 2019, 12:02:13 AM »
PM sent.
Offline kcodecoupe
« Reply #2 on: June 11, 2019, 10:03:08 PM »
are 66 4 bolt upper control arms same as 67
« Reply #3 on: June 11, 2019, 10:38:13 PM »
No. 65/66 are different from 67 and will not interchange. 67- 70 are interchangeable however they have different details that set them apart from each other.
« Reply #4 on: June 12, 2019, 12:20:52 AM »
The 67-68 control arm is wider than 65-66, big difference when put side by side.
« Reply #5 on: June 12, 2019, 10:51:18 PM »
Is there a difference between '67 and '68?
« Reply #6 on: June 12, 2019, 11:00:27 PM »
Reply # 3 - 67- 70 are interchangeable however they have different details that set them apart from each other. For instance in the 70's the 1970 3 rivet version was Fords replacement for 67,68 and 69.
« Last Edit: June 12, 2019, 11:02:29 PM by Bob Gaines »
« Reply #7 on: June 12, 2019, 11:56:12 PM »
So how would I tell a '67 from a '68?
« Reply #8 on: June 13, 2019, 12:26:49 AM »
A 68-70 has the nose shaved for tire clearance
