Author Topic: 70 clutch fork return spring[s] at bellhousing  (Read 4434 times)
Offline bgp429
« on: July 11, 2019, 10:58:22 AM »
Couldn't find anything using the search, does anyone have a picture of the external return spring or springs at the fork. Would like to see the arrangement and attaching points on both ends. Late 70 Dearborn Boss 302. Thankyou
« Last Edit: October 25, 2019, 05:16:16 PM by J_Speegle »
Offline hopeto
Re: clutch fork return spring[s] at bellhousing
« Reply #1 on: October 01, 2019, 06:04:17 PM »
with and without the fork boot. Late April Dearborn. Hope this helps.
Original one owner 84 GT Convertible with 1800 miles. 65 Silver Smoke Gray K Code GT Coupe - 65 Cyclone - 67 Vintage Burgundy K Code GT Coupe.  1970 Calypso Corral Boss 302 - 2012 Yellow Blaze Boss 302.
Offline bgp429
« Reply #2 on: October 02, 2019, 12:42:29 PM »
Thanks, that is what I needed. The pedal return was very light after re-installation of the under dash spring. Someone had "improved" the original design before I purchased the car.
Offline hopey
« Reply #3 on: October 03, 2019, 12:04:28 AM »
Jam nuts are wrong in the photo. They should both be on the inside of the swivel pin, otherwise the adjuster rod will bind and bend.
1970 BOSS 302
Built 11/15/69 Dearborn
Offline hopeto
« Reply #4 on: October 04, 2019, 10:40:53 AM »
Quote
Thanks, corrected.
Offline hopey
« Reply #5 on: October 25, 2019, 02:03:27 PM »
What color should the spring be?
1970 BOSS 302
Offline boss167961
« Reply #6 on: November 04, 2019, 11:22:18 PM »
Semi gloss black
