Author Topic: Replace Gaskets 289 C4 Automatic Transmission  (Read 2344 times)
Offline Ralf
« on: August 03, 2019, 04:14:58 PM »
Hello,
Have to replace different gaskets.
- Transmission Oil Pan Gasket
- Valve Cover Gaskets
- Oil Pan Gasket
What would you recommend best?
- vendor
- quality
- material (cork, rubber - reinforced.....)
Many thanks.
Ralf
Offline ChrisV289
Re: Replace Gaskets 289 C4 Automatic Transmission
« Reply #1 on: August 03, 2019, 05:20:19 PM »
If going concours, cork.  I got my valve cover ones from NPD.  The transmission for my C4 I got off ebay as there are different shapes but you want the perfect inner rectangle one
2009 V6 Mustang Coupe
« Reply #2 on: August 04, 2019, 09:22:48 PM »
Agree all three cork. You'll need to locate (haven't purchased some recently) to find valve cover gaskets with "ears" that match the up outs in your valve covers or remove them and glue them back in the correct location.
Felpro should be able to provide you with an oil pan and C4 pan gaskets in cork still
Offline Ralf
« Reply #3 on: August 05, 2019, 05:34:47 AM »
Conclusion: Felpro cork for all above mentioned gaskets.
I have asked because there are really some alternative materials out there..... e.g. oilpan >> blue rubber reinforced- one piece (or even 3 piece). Have no idea about robustness, leaking, lasting.....
@Jeff, do you have a pic available "with ears"?
Thx to all for feedback.
Ralf
« Reply #4 on: August 06, 2019, 11:40:40 AM »
I recommend OEM Ford cork gaskets for all three. Easy to find on eBay or Amazon.
https://www.ebay.com/itm/4-NOS-Ford-C4-Transmission-Pan-Gaskets-Galaxie-LTD-Mercury-Cougar-C5AZ-7A191-B/293162338515?fits=Year%3A1966%7CModel%3AMustang&hash=item4441d648d3:g:k60AAOSwOdldN1fU
Hello,
- Oil Pan Gasket
- vendor
- quality
Many thanks.
Ralf
Offline Ralf
« Reply #6 on: August 08, 2019, 08:52:33 AM »
I just finished (February of this year) rebuilding the C6 in my car using NOS seals, gaskets etc. No issues. I also used NOS Autolite intake gaskets and valve cover gaskets in my 428CJ. Never heard of or experienced any issues with an old gasket so long as it has been stored properly. The stuff doesn't go bad over time.
Not sure about that "old" stuff can be used wo issues.
Online 67gtasanjose
« Reply #7 on: August 08, 2019, 09:15:56 AM »
+1 except 289 engine (with a C4, though the C4 cork pan gasket is a part from the trans rebuild kit, not OE Ford).
Offline 70cj428
« Reply #8 on: September 05, 2019, 06:33:22 PM »
Quote
Gaskets can shrink over time, haven't really ran into this with Mustangs, but I also play with ww2 Jeeps, and almost all NOS gaskets (both cork and paper) are so shrunk enough that they are unusable ...
Offline rrenz
« Reply #9 on: September 08, 2019, 12:45:27 PM »
I've used the felpro cork without any issues.
Ryan
1966 C Code NJ Springtime Yellow
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
Online jwc66k
« Reply #10 on: September 08, 2019, 02:15:09 PM »
Almost all materials used in WWII were "critical", were required "immediately", and had, by design of available materials, a "limited shelf life". While in the Navy in the 60's, we had a lot of WWII (and Korean War) surplus equipment installed on new ships with a lot of replacement parts from that era to support that equipment. Much of it was bad (read junk) and got tossed overboard (at night). Just confirming your findings, and our disposition.
Online 67gtasanjose
« Reply #11 on: September 09, 2019, 06:19:24 AM »
Hello,
- Oil Pan Gasket
- vendor
- quality
Many thanks.
Ralf
As others have indicated including myself, there are newer gaskets that mimicked the originals but none of them DUPLICATE original gaskets.
If you are concerned about function more than originality, then FelPro should help you just fine. The tabs on the valve cover gaskets would be noticeably different though.
Online 67gtasanjose
« Reply #12 on: September 09, 2019, 06:51:27 AM »
Ralf
"Ears" on the NOS gaskets I used. Others can confirm correctness as they wish. Obviously older gaskets can be drier than new ones. I run an 1/8" diameter, thin continuous bead of "The Right Stuff" brand RTV around the valve cover, circling the holes (AFTER finishing the continuous bead on the insides of the bolt holes). I DO NOT initially install the valve cover PERMANENTLY but I compress the RTV to flow out the RTV (using bolts to keep the holes of the gasket lined up) This can be done bolting the cover down to the head very lightly or by weight on the valve cover on a flat table or bench. The idea is to let the RTV cure completely 100% to seal the gasket to a less than perfect valve cover. You do not want to see any RTV  squeeze out so less is more or use a razor knife to trim off any visible RTV after it cures.
The picture I shared here was taken after I had done the process I just described. I used the "bolt it down lifhtly" method.
« Last Edit: September 09, 2019, 06:56:14 AM by 67gtasanjose »
Offline Ralf
« Reply #13 on: September 25, 2019, 02:28:19 PM »
So, finally all done.
Used Felpro, no Silicon @all.
@Richard
What is the name of the blue colour you have used?
Thx.
Ralf
