Author Topic: 70 door hinge pin and bushings.  (Read 1116 times)
Offline JohnRB
  • 0F03R120303
« on: August 11, 2019, 06:13:25 PM »
Looking for original Ford NOS door hinge pin and bushings. Need both lower and upper for both doors. Let me know what you have.
Re: 70 door hinge pin and bushings.
« Reply #1 on: August 12, 2019, 07:32:58 PM »
The 60-68 MPC lists B9A-5943070-A, pin, cut to length; and C3Az95422841-A, bushing. I don't know what criteria you would use to verify a NOS part from an aftermarket part as neither is marked, and identified by markings on a bag.
Offline JohnRB
  • 0F03R120303
« Reply #2 on: August 13, 2019, 01:16:10 AM »
Because the aftermarked parts I have found does not look anything close to the originals. If you know where they have parts that looks like the original I would try that.
Offline JohnRB
  • 0F03R120303
« Reply #3 on: August 15, 2019, 03:55:57 PM »
Here is what I am looking for.
Offline JohnRB
  • 0F03R120303
« Reply #4 on: August 15, 2019, 04:00:53 PM »
And here is the current repro!
Offline 70cj428
« Reply #5 on: August 18, 2019, 08:59:06 AM »
If you find someone with a small lathe, you can make the repro / aftermarket pins look just like the factory pins. I'd find a local machinist and bring him a few repro pins and an original sample ...
Offline JohnRB
  • 0F03R120303
« Reply #6 on: August 19, 2019, 11:17:39 AM »
Might be possible, but would have been easier to find the right parts in the first place!
Offline JohnRB
  • 0F03R120303
« Reply #7 on: August 20, 2019, 02:41:38 PM »
Anyone used Scott drake door hinge pin kit? How close to the original head marking are they?
https://www.cjponyparts.com/scott-drake-door-hinge-pin-kit-1969-1970/p/HW3018/
Thanks.
« Reply #8 on: August 20, 2019, 05:42:39 PM »
Thanks.
You may not be aware but there is a picture of the head detail in the link you provided so you can compare for yourself to the original picture you posted elsewhere in this thread..
Offline JohnRB
  • 0F03R120303
« Reply #9 on: August 21, 2019, 01:18:33 AM »
Was aware of it, but the head pic is not that good.
What do other people do? Buy NOS hinges or.....?
Offline JohnB
  • 0F03R120303
« Reply #10 on: July 15, 2020, 06:33:44 PM »
Now an then .......
« Reply #11 on: July 15, 2020, 09:42:59 PM »
I had a small Atlas (Craftsman) hobby lathe that was perfect for this and a myriad of other uses. I sold it and bought a much larger 10" Atlas capable of actually dressing  the end of 9" axle shafts!
You can find the smaller lathes used for around $500. And yes, it will pay for itself.
Offline JohnB
  • 0F03R120303
« Reply #12 on: July 16, 2020, 05:54:59 AM »
A friend with a lathe did it for me. Came out perfect.
