Author Topic: drive shaft colors for 1970 Stang  (Read 1345 times)
Offline Bossman963
« on: August 15, 2019, 12:18:04 PM »
I have the build sheet but can't read anything so my question on a general basis what colors would I put on the driveshaft
2-69 B302 -twins, 1-1970 Cougar Eliminator B302- matching numbers, 70 B302 in progress, 68 Charger, 74 Pantera GTS, 2 fox body Mustangs 1 conv
Offline tobkob
Re: drive shaft colors for 1970 Stang
« Reply #1 on: August 15, 2019, 05:35:59 PM »
You shouldn't put any stripes on until you know for sure which colors are appropriate for your particular car (plant,date,engine,trans,etc),
TOB
« Reply #2 on: August 15, 2019, 06:16:45 PM »
To comment we would first need to know when the car was built, engine and transmission combination,
"1970 Stang" doesn't do it
IF the buildsheet is hard to read due to discoloration you might want to read the article about cleaning buildsheets here on the site
Offline Bossman963
« Reply #3 on: August 16, 2019, 01:05:05 AM »
Ok this Boss 302 was built at Dearborn, October 1969, 4-speed close-ratio (code is 6)
« Reply #4 on: August 16, 2019, 01:13:38 AM »
Identification stripes from front to rear for a 1970 Boss 302 from around the same time period are listed as - BUBULAV
Blue - Blue - Lavender
A picture of an original set below - of course colors are not as rich and deep as they were originally in the picture
For an extra - yokes (before they were welded to the tube) were painted orange
« Last Edit: August 16, 2019, 01:34:32 AM by J_Speegle »
Offline Bossman963
« Reply #5 on: August 16, 2019, 12:36:24 PM »
Thanks much Jeff
