Author Topic: HELP! - Installing 4 speed T Handle shifter upper boot  (Read 8317 times)
Offline wcampbell
« on: December 24, 2010, 12:16:57 AM »
I'm trying to install a new 4 speed shifter boot on my existing '65 lever. Given the T-handle is still intact what's the trick to installing a new one? Any pros willing to give the secret would be much appreciated!
« Last Edit: September 10, 2021, 05:07:30 PM by J_Speegle »
Offline Asm109
Re: HELP! - Installing '65 4 speed shifter boot
« Reply #1 on: December 24, 2010, 01:12:51 AM »
Stretch it.  It will go over the T handle.  Even old cracking original boots will stretch over the T
Offline FunStang65
  • Drive and Enjoy!!! Mustang Living
« Reply #2 on: December 24, 2010, 02:52:09 AM »
Soak the rubber boot in nearly boiling hot water for a few minutes to get it soft and then stretch it over the T-handle using a long-handled screw driver as a leverage bar to get it over the t bars. It will work like a charm and it will not rip or tear. I had the exact same question a few years ago and someone gave me this same advice. It worked perfectly.
65 Ivy Green K-Code Convertible
04' Gray GT Convertible
Offline T Lea
« Reply #3 on: December 24, 2010, 08:57:32 AM »
hair dryer
« Reply #4 on: December 24, 2010, 08:34:05 PM »
The repros stretch easier without tearing compared to the originals. Heating the boot up wether in hot water or heat gun/hair dryer +1. Bob
Offline Danno1325
4 Speed T Handle Shifter Boot Install Help
« Reply #5 on: February 13, 2013, 08:08:49 PM »
Hello - I am having trouble trying to install a replacement shifter boot on my 65 convertible.  It has the original 4 speed with the reverse lock out levers on the shifter handle and the hole in new boot is not big enough to stretch over the levers.  Is there some trick to getting this thing installed correctly?  I have a NOS boot and I am worried about stretching it too much as it may rip and it was hard enough finding the NOS one the first time around.  Any help and guidance is greatly appreciated.
« Last Edit: September 10, 2021, 05:10:00 PM by J_Speegle »
Online CharlesTurner
Re: 1965 4 Speed Shifter Boot Install Info
« Reply #6 on: February 13, 2013, 08:21:41 PM »
You either try your luck stretching it over or send it off to someone like Bill Heeley to have him take the cable out so the T can be removed.  Then slide the boot on and re-attach the cable.
« Reply #7 on: February 13, 2013, 08:37:23 PM »
Put the boot out in the sun, preferably on a very warm (75-80F) day for an hour or two. It "may" have enough elasticity to make it over the "T" bar. Careful, it will be hot.
« Reply #8 on: February 13, 2013, 09:26:38 PM »
Of course, you can only put the boot over one side of the t-handle at a time.  I typically use a big screwdriver to help deform the rubber boot.  I've never torn a boot.
Offline Danno1325
« Reply #9 on: February 14, 2013, 06:24:09 PM »
Thanks for the insight I really appreciate the help.  I feel better about stretching the boot and using a screwdriver if you haven't torn one doing it that way.  I appreciate the advice!
Offline preaction
Shifter boot over T handle
« Reply #10 on: November 21, 2015, 12:24:32 PM »
The shifter is a factory stick with the T handle for reverse lockout and I cant seem to figure out how to disassemble it ( T handle ) to replace the boot without damaging it.
« Last Edit: November 23, 2015, 05:21:08 PM by J_Speegle »
Offline Asm109
Re: 67 shifter boot
« Reply #11 on: November 21, 2015, 04:45:22 PM »
Stretch the boot over the T.  It will go.
Offline preaction
Re: 67 shifter boot
« Reply #12 on: November 21, 2015, 04:56:20 PM »
It just didn't seem like that would work with out tearing but I will try thanks.
Re: Shifter boot over T handle
« Reply #13 on: November 22, 2015, 12:26:34 AM »
Replace the boot on a warm day, or at least get it soft in very warm water, like 110-120F.
« Last Edit: November 23, 2015, 05:21:40 PM by J_Speegle »
Re: 67 shifter boot
« Reply #14 on: November 22, 2015, 12:27:23 PM »
