Author Topic: Non-PS V8 Tie rod paint daub / marking  (Read 1041 times)
Offline evantugby
« on: April 14, 2020, 06:13:15 PM »
While restoring my tie rods I Found blue paint or blue wax pencil marking on my 66 k-code metuchen kar.
« Last Edit: April 17, 2020, 04:40:52 PM by J_Speegle »
Re: Non-PS V8 Tie rod paint daub / marking
« Reply #1 on: April 14, 2020, 06:43:57 PM »
Are you sure that's not blue RTV?
« Last Edit: April 17, 2020, 04:41:00 PM by J_Speegle »
Offline evantugby
« Reply #2 on: April 14, 2020, 09:00:46 PM »
Could be.  Who knows.  Blue RTV is a silicone.  The stuff I found appears to be grease-based pencil.  That's how it looks to me but who knows what happens after 55 yrs.  In addition, they were only found on the outer tie rods.  Not sure why the inner tie rods wouldn't have it, if it was RTV.
« Last Edit: April 17, 2020, 04:41:15 PM by J_Speegle »
« Reply #3 on: April 14, 2020, 10:00:27 PM »
Grease based marker (like big crayon) would not be the way these would have typically been marked if marked. Paint was the typical product and this appears to have some thickness to it - more like RTV would have
The RTV might have been used to "glue" the boots in place and keeping them from coming loose.
« Last Edit: April 17, 2020, 04:41:07 PM by J_Speegle »
« Reply #4 on: April 14, 2020, 10:45:19 PM »
Looks like RTV or some type of sealer.
The boot on that seal looks cracked, so obviously not usable, but I usually remove these with a piece of wood like a paint stirring stick and tap off with a hammer.
« Last Edit: April 17, 2020, 04:41:23 PM by J_Speegle »
Offline evantugby
« Reply #5 on: April 14, 2020, 11:56:00 PM »
It very well could be RTV, who knows.  The important thing is that another clue was found.  I just don’t know why it would only be on the outer tie rods.  The pictures are of two Different outer tie rods.  I have another unusable set that I’m going to pop off the boots to see if I can find more of the blue stuff.
« Last Edit: April 17, 2020, 04:41:30 PM by J_Speegle »
Offline ChrisV289
« Reply #6 on: April 15, 2020, 12:09:45 AM »
It is not a paint mark. I also found it under the boot of my original tie rods. It was discussed in another thread
« Last Edit: April 17, 2020, 04:41:37 PM by J_Speegle »
2009 V6 Mustang Coupe
« Reply #7 on: April 15, 2020, 12:45:42 AM »
Yes, there is a blue dab as seen in the first picture. I also used blue RTV to seal the ball stud for bead blasting and phosphting, as seen in the rest.
« Last Edit: April 17, 2020, 04:41:43 PM by J_Speegle »
Offline sgl66
« Reply #8 on: April 16, 2020, 09:38:18 PM »
Can’t tell from your pics but the nuts for the tie rod adjusting sleeves on my October Metuchen car have some type of red plastic or loctite on one of the 6 nut faces. Also, while you’re in there, the end of the center link under the pitman arm has a yellow dab of paint. This isn’t a very good picture, it’s the same yellow inspection color found in other areas.
« Last Edit: April 17, 2020, 04:41:50 PM by J_Speegle »
« Reply #9 on: April 17, 2020, 01:21:21 AM »
The red plastic is to make the nut a lock nut. It would not be out of the ordinary for all of the adjusting nuts to typically be of the same locking variety .
« Last Edit: April 17, 2020, 04:41:58 PM by J_Speegle »
« Reply #10 on: April 17, 2020, 01:25:08 AM »
I've mostly seen pink there on 65 cars.
« Last Edit: April 17, 2020, 04:42:15 PM by J_Speegle »
