Author Topic: 1967 Mustang Emergency Brake Handle Assembly  (Read 2836 times)
Offline tgilliam
« on: May 03, 2020, 01:08:03 PM »
Looking for how the "H" shaped detent & spring go into the body of the E-Brake handle body. This fell out while I was cleaning it up before I could see exactly how it goes together. Any help or a detailed picture would be a tremendous help and appreciated. Thanks in advance.
Tom Gilliam
tom@jtgil.com
Re: 1967 Mustang Emergency Brake Handle Assembly
« Reply #1 on: May 03, 2020, 08:55:47 PM »
Here, these should help
Offline tgilliam
« Reply #2 on: May 03, 2020, 10:14:00 PM »
Richard, Thanks a million. That is exactly what I was talking about. In your third picture, is that the short end of the spring that can be seen sticking out by the ear on the detent? I appreciate you taking time to get these pictures and post them.
Tom Gilliam
tom@jtgil.com
« Reply #3 on: May 04, 2020, 04:58:06 AM »
Tom Gilliam
tom@jtgil.com
I took these apart for replating the parts a few weeks ago so these were to be my reassembly images. I figured these were all I needed but without the pieces in my hands (pieces are away at the replater service), I cannot answer your question.
Offline Blue_67_Fastback
« Reply #4 on: May 05, 2020, 02:50:37 AM »
Hallo Tom,
i rebuild mine two years ago and had the same problem… the short end of the spring goes to the H-detent, the long one towards the handle. It will “push” the detent down so it engages with the saw-tooth of the handle when pulling out.
You can easily check the function without cables and Installation.
enno
1967 Fastback, C Code, 3 Sp MT, 7F02C169xxx, Build Date 3/2/67
First Mustang Club of Germany 1964-73 e.V.
Offline tgilliam
« Reply #5 on: May 05, 2020, 06:38:58 PM »
Blu_67_Fastback,
Thank you for the follow-up information and pictures. I can see the "long tail" of the spring clearly in your pictures. I believe that will help me get mind back in the correct operating position.
Tom Gilliam
tom@jtgil.com
Offline kkupec02
« Reply #6 on: May 07, 2020, 12:16:54 AM »
How do you get the handle off? Do you drill out the pin?
1967 GT500 Built 1/26/67 #817
1967 Corvette Roadster
« Reply #7 on: May 07, 2020, 12:40:46 PM »
To remove the handle I use vice grips on the plastic to bust it away revealing the metal assembly below. Then I pry the metal tube off the stalk leaving the rivet in place. With the metal part out of the way you can grasp the pin with vice grips an pull it out. That way the hole is undamaged by drill bits.
Offline tgilliam
« Reply #8 on: May 07, 2020, 09:32:27 PM »
My experience was - When you break the plastic off the metal tube of the handle, I found the hole in the handle goes all the way through. The pin can be driven out from the opposite side.
Tom Gilliam
Offline bullitt68
« Reply #9 on: May 08, 2020, 02:24:44 AM »
Hallo Tom,
enno
Thanks for posting ENNO. Are all your parts original?
Mike
Offline tgilliam
« Reply #10 on: May 10, 2020, 11:55:30 AM »
Good Day bullitt68,
I believe the unit I am working on was the original assembly line handle assembly.
Tom Gilliam
Offline bullitt68
« Reply #11 on: May 10, 2020, 09:03:07 PM »
Good Day bullitt68,
Tom Gilliam
It looks like it was in great shape
Mike
« Reply #12 on: May 11, 2020, 02:31:14 AM »
Yes, it should be.
It has the "FoMoCo" Logo stamped on the side of the handle.
Offline bullitt68
« Reply #13 on: May 11, 2020, 03:03:25 AM »
Yes, it should be.
Nice. Mine does not appear to have a FoMoCo stamp. I thought it was original until now. I wonder if any originals did not have a stamp or should I start assuming mine is not original
« Last Edit: May 11, 2020, 03:25:20 AM by bullitt68 »
Mike
« Reply #14 on: June 16, 2020, 11:00:42 AM »
This spring at the cable attaching point, how does it go back?
(My service manual is at home, if it even shows any help).
