Author Topic: Axle Ends Paint Markings - 31 spline, 9"  (Read 1169 times)
Offline Mike_B_SVT
« on: June 01, 2020, 05:43:24 PM »
Ok, I found what appear to be marks on the ends of my axles and want to confirm what I think I'm seeing.
1970, Dearborn, Oct 6th build date, 9" with 31 spline axles, 3.91 gear ratio.
Driver's side axle end ~ painted white with a pink line / slash?  And a little white squiggle, like an initial / inspector mark?
Passenger side axle end ~ possibly a yellow blob and another initial squiggle?  Or is that just a different shade of rust?
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
Offline 1970 Snake
Re: Axle Ends Paint Markings - 31 spline, 9"
« Reply #1 on: June 08, 2020, 03:06:12 PM »
Hello Mike, just wanted to confirm your findings as my axle also have the white and pink markings on them, there where also pink markings along the axle between the carrier and the outer hub. I will try and dig up some pictures when I have time.
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Offline Mike_B_SVT
« Reply #2 on: June 08, 2020, 04:16:19 PM »
Thanks!  Anything on your passenger side axle?
Mike B.
Cat Bites Man!
« Reply #3 on: June 08, 2020, 07:28:12 PM »
Have two examples with blue swipe on the axle end. One on a car one on a NOS example
Sorry don't have the same for the DS for your application
As a reminder for all ;)  Make sure all the other details on your restoration are up to standards/original before you worry about paint marks and daubs. They don't make up for  falling short in other areas and adding paint marks to a poor reproduction part is just plain silly IMHO
Offline 1970 Snake
« Reply #4 on: June 28, 2020, 09:41:23 PM »
As indicated previously in this topic here are a couple of pictures of my replicated white and pink markings as found during disassembly of my axles
« Last Edit: June 28, 2020, 09:47:30 PM by 1970 Snake »
