Author Topic: Door courtesy light harness grounding location  (Read 602 times)
Offline bjf1992
« on: July 30, 2020, 10:54:42 PM »
1969 Dearborn April 69 build Cougar.
Trying to remember where the door harness grounds go. (I'm assuming the same as Mustang, but not sure)
Does it piggyback on the existing ground screw in the lower dash or go somewhere else?
1969 Q Code Standard Cougar Convertible P/S, P/B, A/C
Pastel Grey, Lt. Blue interior Black Top
Built April 2nd, Dearborn
1969 Mustang Sportsroof
September 68 Build date, Metuchen
Offline bjf1992
Re: Door courtesy light harness grounding location
« Reply #1 on: July 30, 2020, 10:55:26 PM »
Same question on the passenger side.
« Reply #2 on: July 31, 2020, 12:45:34 AM »
Can confirm that it typically does not share the same spot as shown in your first picture. More likely but have not confirmed on another car that they connect to the hles just below the upper door hing cut out and the one below that opening on the inner body panel.
« Last Edit: July 31, 2020, 12:49:08 AM by J_Speegle »
Offline bjf1992
« Reply #3 on: July 31, 2020, 12:23:04 PM »
Awesome Thanks!!
