Author Topic: Radiator question  (Read 1251 times)
Offline HDAshmore
Radiator question
« on: August 06, 2020, 10:07:37 PM »
Team,
Can someone tell me what a C9ZE M1 radiator goes to?  I don't know why I have it or where it came from.
Thanks Dan in Kansas
Online jwc66k
Re: Radiator question
« Reply #1 on: August 07, 2020, 12:06:00 AM »
Dan,
There is a link to Ford Car Parts, aka MPC (65 to 72) in the library in the article list for each major year. Your radiator question is a good way for you to familiarize yourself with the MPC.
Offline HDAshmore
« Reply #2 on: August 07, 2020, 03:50:12 PM »
Jim,
Thanks, I did do that search first before posting.  I guess I'm not attune enough to translate the Part number and engineering number.  Using the find feature on the document brought up nothing for C9ZE M1 to even cross reference.
That when I decided to try to tap into the collective members wisdom.
Appreciate the recommendation and feedback.. Ill keep looking.
Dan
« Reply #3 on: August 07, 2020, 04:22:50 PM »
MPC section 80 page 2 radiator cross reference - identification number C9ZE-8005-M is serviced by C9ZZ-8005-E
section 80 page 7 shows that the C9ZZ-8005-E service part is used for 69 Mustang, 6 cylinder 250 from 12/16/68.  Standard and extra cooling and AC.  Typical for service radiators to span a wide range of uses.  Also it was pretty typical for all service radiators to have the automatic transmission cooler.
Also used for 70 Mustang 200 & 250 6 cylinder models, as well as 302 (except Boss), and 351 engines.  It was not used though for the 351-4V with 3.5/1 axle ratio.
Dimensions 20-1/4 by 16-7/16 by 1-1/4
This should provide clues...but it is not "factory correct" per se.
Offline Hipo giddyup
« Reply #4 on: August 13, 2020, 10:58:13 AM »
This radiator is the same I just removed from my 1970 351 2v MachI.
