Author Topic: Window regulator recommendations  (Read 587 times)
Offline Kascus
« on: September 07, 2020, 01:38:29 PM »
Any particular brand window regulator for a 68 y’all recommend?
Current:
1964.5 289 D Code Coupe / Dearborn 06-05-64
1966 289 C Code Convertible /San Jose 02-11-66
Past:
1965 Shelby SFM5S561
1968.5 428 CJ Fastback / San Jose 05-15-68
1966 289 FB
1965 289 Coupe
1969 302 Fastback
Re: Window regulator recommendations
« Reply #1 on: September 07, 2020, 02:05:19 PM »
FOMOCO . ;) A nice used original will cause the least amount of issues. Given the number of cars produced there are literally thousands of nice used ones still in the wild. If you can't find any I most likely have some off of junked out doors.
Offline Kascus
« Reply #2 on: September 07, 2020, 02:45:21 PM »
I have a set of originals but the teeth are very worn.
Current:
Past:
1966 289 FB
1965 289 Coupe
1969 302 Fastback
« Reply #3 on: September 07, 2020, 04:01:25 PM »
Not all originals are going to have worn teeth. It sounds like you need to find another set. The repros will work but typically do not have as smooth of a action as original quality.That is why many don't like to use them. I agree A 1 800 repro parts number is the easy button here.
« Reply #4 on: September 07, 2020, 06:52:50 PM »
Seldom are we able to put a used 1967 or 1968 door window regulator in stock at WCCC. Over 90% of the ones I check have very bad slipping clutches. Can push windows up or down all the way or a few inches.
