Author Topic: 65-66 parts  (Read 1370 times)
Offline gary c bergman
65-66 parts
« on: October 15, 2020, 06:02:16 PM »
cleaning garage & tool boxes of not needed parts, mostly 65-66 parts that may be helpful to someone! All plus shipping......email: garycbergman@gmail.com  or  call 402-480-3545
1. Vintage 6.95 X 14 Firestone Deluxe Champion tire-probably a 68 style (nice spare tire/never used)  $50
4. Radiator Tag  C8ZE  D2    AMK product with instructions  $8
5. original 1965 coil spring perch with tack welded attaching bolts and nuts  $20
7. 1965 Engine Gauge Feed wiring —part # 14289-2C with 2 speed heater  (Alloy Metal Product)  $20
8. 65-66 door striker plates  (dated 1-65, 8-65, 1-66, 1-65)  $10 each
9. original Ford C90E-8592-B water outlet connection (nice condition)  $15
10. spare tire  1/2-13 wing nut  AMK Product  $3
11. Spacer, pulley to fan C8AE F with original diamond head attaching bolts  (2 5/8 inch tall)  $10
12. Ignition coil strap (not sure about application) $10
15. HEK-M Borg Warner T-10 transmission tag with 2.36 1st gear  b4 23 Nov 64  $20
16. 65 A/C Evaporative Drain hose cover  $40
17. original Ford Seat side hinge cover (Ivy Gold, passenger side)  $15
18. Lamp kit for engine or trunk compartment (new in package)  $8
19. original Ford, two barrel carb to manifold spacer with Felpro gasket  $20
20. original Ford, Carb to manifold spacer for 69-70 Boss 302  $65
21. factory original Autolite C6DF-14431-A cable from engine block to solenoid (nice for its age, but has one crack) $25
22. 65-66 Air vent assembly (drivers side)
23. 65 Heater case without resistor hole
25. misc. original 65-66 fastback fold down parts (latch cover, latches, seat leveling shims, bumpers, knobs)  call
27. 65-66 reproduction fastback rear seat panels (right and left w/original inside supports)  $200
28. original 66 horn  LO note (finger/tab style)  may/may not work  $10
29. NOS front bumper guards C5ZZ-17997-B (right and left)  $100
30. Autolite carburetor tag for 67 2V           AUTOLITE   C7DF   R    B 7BA   $10
31. 65 and 66 radio support brackets  $20 each
32. 64 1/2 radio for parts (nice chrome face, no cut wires)  $20
« Last Edit: April 03, 2021, 07:45:09 PM by gary c bergman »
Offline outlawincorporated
  • Kangaroo Herder
Re: 65-66 part
« Reply #1 on: October 15, 2020, 06:15:17 PM »
interested in the fuel pump and heater plenum, can you send some further images to; outlaw@hn.ozemail.com.au
regards
PHILL BERESFORD
MELBOURNE.
AUSTRALIA
Offline Building 3
Re: 65-66 parts
« Reply #2 on: October 18, 2020, 01:25:13 PM »
is the heater plenum still available? If so, i would like to buy it.
Offline gimmea250swb
Re: 65-66 parts
« Reply #3 on: October 25, 2020, 10:46:44 PM »
Hi Gary ,could you send me a photo of the 2-66 striker plate?
'66 Shelby Feb build
'65 FB 5T09T164019
Offline mmus65tang
Re: 65-66 parts
« Reply #4 on: November 11, 2020, 04:34:57 PM »
Hi, in your picture of parts you have a couple of brake distribution blocks. One looks like the Disc brake 3 port distribution block. Is that what you have? How much do you want for it.
Mike
Offline uapilot
Re: 65-66 parts
« Reply #5 on: February 20, 2021, 10:17:10 PM »
Hi,
Do you still have the 66 radio support?
Let me know,
David
