Author Topic: Wanted 66 HiPo radiator / automatic  (Read 701 times)
Offline nashvet
« on: February 24, 2021, 09:35:07 PM »
Looking for Radiator for 1966 HiPo San Jose build.  would like 11 or 12/65 date code.
Re: Wanted 66 HiPo radiator / automatic
« Reply #1 on: February 25, 2021, 12:29:49 AM »
Welcome to the forum. I assume you have a HP with a C4. Any San Jose V8 with a radiator for an automatic transmission is correct for your car. The way to identify the radiator is the tank is stamped "W-MO" with the date, month and year in numbers (mine is 9-65), stamped from the inside and read up side down (read correctly from the engine compartment). There "may" be a part number tag on the top, "C4ZE H2".
I wasn't sure if this specific marking information was in the Forum's Library, it is, under thread title
"ConcourseMustang.com Official 66 Mustang Article List" and scroll down to the date code topic. It is an Adobe .pdf file. You want page 35.
« Last Edit: February 25, 2021, 12:37:32 AM by jwc66k »
« Reply #2 on: February 25, 2021, 05:50:39 AM »
Sorry not to take anything away from your search for a radiator for your car. Other automatic K codes from your same period have been documented with C4ZE-M2 soldered on ID metal tags that it should have.
If you want to read more about the change over to the soldered on tag verses the earlier tank  stamped ID its covered in the thread below.
Welcome to the site and good luck with your search
http://www.concoursmustang.com/forum/index.php?topic=19068.new#new
« Reply #3 on: February 25, 2021, 01:11:58 PM »
AMK lists the "C4ZE M2" tag as used on 1966 (64 and 65 V8's as well) 289 V8 with Air Conditioning, and "C4ZE M2" without A/C. Comments?
Offline 68GT/CSconvmod
« Reply #4 on: February 25, 2021, 04:26:58 PM »
Try Bob Schirmer in Wisconsin he rebuilds them, He may have tanks and straps and can put one together. 1-800-537-3775
Or Kevin Manley
kevinmanley2005@yahoo.com
Troy
« Reply #5 on: February 25, 2021, 08:13:54 PM »
No - especially no further discussion in the gentleman's wanted ad.  :)
