Author Topic: 69 Mach 1 Back bench back seat removal/release  (Read 2685 times)
Offline keeper
« on: March 06, 2021, 03:37:12 AM »
Can any one give me a tip or two as to how the back bench seat back rest comes loose. I am too big to crawl into trunk to get at bolts. I am attempting to detail area trunk  behind seat.  Thank you, Keith
Keith 69 Mach1TopLoader/Vcode SJ
Offline 1966KGT
Re: 69 Mach 1 Back bench back seat removal/release
« Reply #1 on: March 06, 2021, 08:57:00 AM »
Been a while since I had mine out but if memory still serves me you fold front seat forward and push down and towards the rear on lower seat on both sides and remove rear seat and  there are two fastners easily spotted to remove backrest.
Online 69GT350H
« Reply #2 on: March 06, 2021, 10:44:40 AM »
I think, if I remember correctly, for the backrest, there are two screws that hold the fabric down at the bottom. You can see them once the bottom seat is removed. Then the backrest slides up off the two hooks located at the upper outer edges.
Offline keeper
« Reply #3 on: March 06, 2021, 11:55:09 AM »
 It sounds as though I need to get the bottom seat moved out of the way and then it will expose some fastener bolts for the back rest. They must be in two sections. Thanks for the help guys.
Online 69GT350H
« Reply #4 on: March 06, 2021, 06:42:42 PM »
Yes, the bottom comes out 1st. For the bottom, in each of the sitting positions, grab the front edge, push toward the back of the car, once it moves back an inch or so, the front edge will lift up. Repeat again for the 2nd seating position, and the seat will come forward and will lift out.
Offline keeper
« Reply #5 on: March 08, 2021, 02:13:41 AM »
Thanks for the tips. I will attempt it again after I chill for a while.
