Author Topic: Brake hose marking restoration  (Read 948 times)
« on: March 24, 2021, 01:13:09 PM »
My brake hose is clean, in good shape and the end fittings have been re-plated.
I've made a scaled drawing of what the original markings should be.
For those who have re-marked their hoses, what process worked for you?
Re: Brake hose marking restoration
« Reply #1 on: March 24, 2021, 05:59:53 PM »
I was hoping to avoid a lot of experimentation -- but this is my life.
I sourced some vinyl sign cutting scraps that had "scales" cut out of them and did a film transfer to a cleaned up old hose.
I didn't take the greatest of care in the application (like I would if I was really doing this) but here a few pics. Yeah, it's the inverse of how numbers are laid down but I was looking for how well the vinyl prevents bleed.
There is a little bleed as the film isn't perfectly laid down but this shows promise . . .
The color isn't too bad considering I wanted a gold/orange color.
« Last Edit: March 24, 2021, 06:01:58 PM by Bossbill »
« Reply #2 on: March 24, 2021, 06:01:08 PM »
pics??
« Reply #3 on: March 24, 2021, 07:01:04 PM »
Over the years adding pics has proven troublesome.
I can add, at most, one pic using the attachments button. Subsequent pics I add by modifying the post and adding more pics. You see most of my picture posts have the "post modified at [timestamp]" at the bottom.
If I try and add 2 or more pics the session hangs and I get a white screen. If I do a "browser back" chances are poor anything got posted at all.
Today, even adding one failed. So I posted the text and go in and add the pics using the "Modify" feature. Judging by your time stamp you must have read the text between the post and modify.
