Author Topic: Was dual exhaust a factory option on '65 A-code non-GT?  (Read 2597 times)
Offline ramori
« on: June 03, 2021, 10:12:15 AM »
My 5F07A coupe has dual exhaust, and I'm assuming it was factory installed. Build date 11AUG64.
Some are telling me no way, dual exhaust was only available for k-code and GT models, and it must be aftermarket.
I'm not the original owner, and there is no Marti report for my car.
Can one of you Concours gurus verify that dual exhaust was an option for A-code coupes?
Is there a tell, underbody, that can prove mine were factory installed?
1965 A-code Coupe, Ivy Green with White vinyl top
5F07A2570**  65A R 29 11H 35 1 6
Offline ChrisV289
Re: Was dual exhaust a factory option on '65 A-code non-GT?
« Reply #1 on: June 03, 2021, 10:27:22 AM »
The only cars from the factory with dual exhaust were k codes and factory GTs (A and K codes only). Everything else was single exhaust. Dual exhaust requires reinforcements in the rear frame rails and the rear seat pans. More than likely your exhaust was added by a previous owner.
2009 V6 Mustang Coupe
Offline rocket289k
« Reply #2 on: June 03, 2021, 10:58:57 AM »
+1
Ron
Offline ramori
« Reply #3 on: June 03, 2021, 11:09:39 AM »
Thanks for the quick reply. Don't get me wrong, I like the dual exhaust, but now I'm a bit disappointed that my car isn't as original as I had always thought. Everything else seems to be original,, but now I have to look deeper..
I've owned it for about a year (3rd owner) and I don't know much about its history besides some older maintenance records and what I can see with my (untrained) eyes.
« Reply #4 on: June 03, 2021, 11:11:59 AM »
pull the rear seat bottom. take some pics and post them then we will know for sure.
Offline rocket289k
« Reply #5 on: June 03, 2021, 11:57:39 AM »
You will be looking for a reinforcement plate like this on the rear seat floorpan (outline denoted by red arrows) + factory exhaust hanger (purple arrow).
Ron
« Last Edit: June 03, 2021, 12:06:51 PM by rocket289k »
« Reply #6 on: June 03, 2021, 01:01:37 PM »
In early 1965 (3/25/65) Mustangs got a different dual exhaust system (previously it was an Arvinode Dual Exhaust System) for cars with the HP engine. This same dual exhaust system was used for 65 and 66 Mustangs with the GT option. Here are some pictures that detail the changes to the frame rails at the rear to mount the exhaust pipes.
The first picture is the "key". Note the instruction to insert a finger in the assembly line hole in the frame rail to "feel" the crush tube (aka spacer). The crush tube is shown in picture 2. All 64-66 dual exhaust cars will have this crush tube. The last two pictures show what's inside the frame rail (pictures are from e-bay). There are two crush tubes per car, one on each side. If there are no crush tubes, it is not a dual exhaust car.
Note: The crush tubes can be installed with "determination" to fake make a dual exhaust Mustang. Ask Jeff.
Edit: Years in first sentence were 1964.
« Last Edit: June 03, 2021, 07:56:35 PM by jwc66k »
Offline Scott302
« Reply #7 on: June 03, 2021, 05:01:27 PM »
Jim,
I think you will want to edit the dates you posted.  You meant to type 1965 and 3/25/65!!!
"In early 1964 (3/25/64) Mustangs got a different dual exhaust system (previously it was an Arvinode Dual  Exhaust System) for cars with the HP engine."
Seeing that his car has a scheduled date of 8/10/64, a true dual exhaust car for that date would have received the transverse muffler dual exhaust system.
Scott Halseth
Ford Product Manager
National Parts Depot
MCA#01776
« Reply #8 on: June 03, 2021, 06:06:45 PM »
Agree -
The original question has an easy and straight forward answer though if your going to discuss the features and identifying a dual exhaust car then the first question would be when the car was likely built since that first "year" had multiple systems and features
Offline ramori
« Reply #9 on: June 03, 2021, 06:33:54 PM »
My VIN: 5F07A25010
Build codes: 65A  R  29  11H 35 1 6   (Aug 11 1964 Dearborn scheduled build date)
I removed the rear seat, here are the photos. I didn't see either of the tell-tales that were shown in Ron's photo, but maybe my photos are of the wrong area? I didn't take a photo of the tunnel.
Can someone review the photos and comment please?
« Reply #10 on: June 03, 2021, 07:57:29 PM »
Jim,
Corrected dates on my original post. Thanks Scott.
« Reply #11 on: June 03, 2021, 08:12:55 PM »
My VIN: 5F07A25010
Your car never came with a dual exhaust system from the factory. Do the "stick your finger in the rear frame rail" test to prove that to yourself. That is the easiest "test".
« Reply #12 on: June 03, 2021, 10:35:22 PM »
Jim, even if the car was an August '64 K code, it wouldn't have had that reinforcement in the rear frame rails since transverse and arvinode didn't use the further back hanger configuration like a GT style system.
« Reply #13 on: June 04, 2021, 12:15:51 AM »
True. The Mustang in question did not come from the factory with dual exhausts.
Attached are pictures of the rear frame rails with Arvenode provisions, used only with "K" code Mustangs.
One other point. The first "K" code Mustangs, which would have the Arvenode Dual Exhaust System, were produced in June, 1964, the 6th, 7th or 8th.
« Last Edit: June 04, 2021, 12:32:34 AM by jwc66k »
Offline warwick
« Reply #14 on: June 04, 2021, 02:30:39 PM »
For a while there was a crush tube replacement on market-is there one now?  Does anybody have any.
I am restoring a 66 K Code with rear rails replaced without them.
Thank you
