Author Topic: Throttle Spring color 351C 2v  (Read 1957 times)
Offline BHStang
« on: July 31, 2021, 01:28:22 PM »
If I recall correctly the throttle return springs on top of the manifold hooking to the carb are color coded?  Anyone know what is the correct color for a 1970 H code 351C 2v.  Should it matter its a June 10 1970 DAP Mach 1.  With AC, Manual Trans, Power Disk, PS.
1970 Mach 1
H Code 351C 2v
DAP June 10, 1970
4 Speed Close
AC, PS, Power disk, Shaker, Rear Spoiler
Re: Throttle Spring color 351C 2v
« Reply #1 on: August 02, 2021, 01:32:50 AM »
If the MPC list of applications reflects the applications for C9ZZ-9737-G on the assembly line and not just for replacement parts then that spring was shared with a number of other applications in 69 and 70 including 6 cylinders and Boss 429's. And thanks for including the date (might consider placing some of this in your signature) since it did make a difference
Here is a section of that page in the final 75 MPC version showing your application
With that said I see one currently on Ebay and it is a light gray color. At the moment can't confirm that I've got an original car showing any colors for 70's
Offline cobrajet_carl
« Reply #2 on: April 02, 2022, 02:22:54 AM »
Assembly manual lists light blue for the color for 2V and silver for 4V.
« Last Edit: April 19, 2022, 03:14:32 PM by cobrajet_carl »
Carl
70 and 71 Dearborn mach Is
Offline BHStang
« Reply #3 on: April 28, 2022, 03:58:04 PM »
..and so blue it shall be.
1970 Mach 1
H Code 351C 2v
DAP June 10, 1970
4 Speed Close
