Author Topic: 1970 leaf spring bottom spring  (Read 1478 times)
Offline BHStang
« on: August 03, 2021, 05:57:54 PM »
Looking for 2 bottom leaf springs bottom spring only showing the stamped engineering # D0ZA-5556
1970 Mach 1
H Code 351C 2v
DAP June 10, 1970
4 Speed Close
AC, PS, Power disk, Shaker, Rear Spoiler
Re: 1970 leaf spring bottom spring
« Reply #1 on: August 04, 2021, 01:51:54 AM »
In an effort to help I take it from your post that you can't read the end of the engineering number on either leaf. Would follow what you posted.
Guess you don't have a buildsheet but we may be able to help you focus your search better. If you would PM me the cars options and build date (either one may help) and I'll see if I can help out
Might want to add this info to your signature as others have to eliminate this step when posting in the future ;)
Offline BHStang
« Reply #2 on: August 06, 2021, 11:05:53 PM »
Jeff
Sent you a message.  I got the engineering number from the MPAC.  I could be reading it wrong though.  Also details on my signature line now.
1970 Mach 1
H Code 351C 2v
DAP June 10, 1970
4 Speed Close
Online 67gta289
« Reply #3 on: August 07, 2021, 07:21:33 AM »
Since you have a 351 Mach 1 (body style 63), according to the MPC it lists: C9ZA-5556-F, or D0ZA-5556-G, or D0ZA-5556-H
Most likely this is due to engineering changes that occurred during the model year.  As is often the case, your build date and assembly plant will play a role in determining the best choice.  Will need input from owners of similar cars.
With no other information, and a car that late in the model year, I would lean towards either D0ZA-5556-G or D0ZA-5556-H
Offline BHStang
« Reply #4 on: August 07, 2021, 08:11:25 PM »
That was the conclusion I was coming to.  I think ill take a G set or an H set just depending on what I can find.
1970 Mach 1
H Code 351C 2v
DAP June 10, 1970
4 Speed Close
« Reply #5 on: August 08, 2021, 07:28:16 PM »
Did finally get around to checking buildsheets and though they don't spell out which springs were installed but given when you car was built it was likely D0ZA-5556-H and possibly D0ZA-5556-G.
Offline BHStang
« Reply #6 on: September 02, 2021, 11:47:16 PM »
Ill put my offer out at $200 + shipping should anyone have a pair to offer.
1970 Mach 1
H Code 351C 2v
DAP June 10, 1970
4 Speed Close
Offline Angela
« Reply #7 on: September 13, 2021, 10:08:26 AM »
I only see the stamping on one (1) spring I have, but perhaps this helps you in some way?
