Author Topic: Gas Cap screw off type cap.  (Read 1795 times)
Offline Kyle Zammit
« on: August 22, 2021, 09:14:55 AM »
I am looking for this small type cap.If anyone have one New or Used let me know please. Send me on this email kylezammit123@gmail.com
Re: Gas Cap screw off type cap.
« Reply #1 on: August 22, 2021, 01:08:27 PM »
A year might help.
Offline Kyle Zammit
« Reply #2 on: August 22, 2021, 02:08:26 PM »
Sorry I didn't understand you well.
« Reply #3 on: August 22, 2021, 02:14:48 PM »
What year car?
Offline Kyle Zammit
« Reply #4 on: August 22, 2021, 04:21:49 PM »
It's a 1967 Shelby GT500.
« Reply #5 on: August 22, 2021, 06:13:56 PM »
That's the inside of the 67-up pop open gas cap.
Underneath this is a screw and washer which allows one to remove everything from the swing-away cap and have it replated.
Pulling this off without destroying it is tricky.
I just did this in my build thread.
Another way of removing these is to sharpen a very small screw driver and pry the lips inward. It usually just comes out easily after the radial pressure is released. Afterwards find a thick piece of DOM (2"?), salami cut it and turn it into a curved anvil to straighten the edges. Then plate. Other ideas on removing are in the same portion of my build thread.
Spares are only available via others' gas caps. I supposed one could could just find a crappy spare pop-open top, cut the spring and standoff on the chrome side and get a punch in from the backside to remove it.
« Last Edit: August 23, 2021, 03:03:32 PM by Bossbill »
Offline Kyle Zammit
« Reply #6 on: August 23, 2021, 01:50:20 PM »
Ok thanks Bill.
« Reply #7 on: August 23, 2021, 03:09:23 PM »
For those of you who haven't taken one apart, here it is, in order of reassembly:
* flip open top
* spring (stainless says my magnet)
* spring cap (items not shown next)
   - seal around outer edge where you see sealant. Seals against gas tank elbow. Not cork but a synthetic gasket
   - seal around inner portion one step above where screw sits. Seals pressed in cap on bottom. This one is cork.
* screw with rather thick washer
* pressed in cap which is the item of interest
To get the cap out you destroy a spare and ugly flip open top to gain access to the stud (into which the screw inserts). Grind away at the side of the stud so the screw releases. Insert a drift and lightly tap the cap out.
« Last Edit: August 23, 2021, 03:16:33 PM by Bossbill »
Offline Kyle Zammit
« Reply #8 on: August 23, 2021, 04:02:08 PM »
Thanks Bill.
« Reply #9 on: August 23, 2021, 06:00:08 PM »
* flip open top
   - seal aroun....................
Bill is this posted elsewhere on the site? May have missed it if it is. If not think we need at least to place it there (with a related thread or its own). Not sure if anyone is going to look here in the wanted section, for a how to.
Just a thought
« Reply #10 on: August 23, 2021, 07:27:07 PM »
I was PMing Kyle and I said "I should make this its own thread."
I will and remove my reply with a link to the new thread. I'll include stuff from my build thread.
Offline 67350#1242
« Reply #11 on: August 24, 2021, 11:09:27 AM »
I wonder if that cover couldn't be removed with a paintless dent removal tool (hot melt glue)?
Probably would be worth a try.
Kurt.
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
