Author Topic: Steering column turn signal harness wire 10 pin connector color  (Read 929 times)
« on: October 20, 2021, 07:19:40 PM »
I'm not even sure how tell if the wire connector is original or not!
Re: Steering column turn signal harness wire 10 pin connector color
« Reply #1 on: October 20, 2021, 08:00:05 PM »
White, am color blind, what is rosy brown? is that dirty white?
« Reply #2 on: October 20, 2021, 08:34:51 PM »
+1 Marty
Offline kkupec02
« Reply #3 on: October 20, 2021, 09:57:22 PM »
my original is white
1967 GT500 Built 1/26/67 #817
1967 Corvette Roadster
« Reply #4 on: October 20, 2021, 10:05:54 PM »
Rosy brown is now updated to be Reddish brown.
« Last Edit: October 20, 2021, 10:09:17 PM by Bossbill »
Online midlife
« Reply #5 on: October 20, 2021, 10:43:46 PM »
All correct.  The plastic becomes discolored with age.
« Reply #6 on: October 21, 2021, 12:20:21 AM »
Original is white, it turns brown and NPD sells one that is black.
« Reply #7 on: October 21, 2021, 11:22:59 AM »
I believe you will find (if enough research were done) that variations exist by suppliers and dates. Keep also in mind that a Tilt column connector color COULD be different at the same assembly location & date.
FWIW, mine was also a dirty white color.
« Reply #8 on: October 21, 2021, 12:43:44 PM »
I did remove the harness from my column and found a red Ford C7 tag on the wires.
I'll take a pic later. I take pics of everything -- except this.
Online midlife
« Reply #9 on: October 21, 2021, 10:55:42 PM »
That is so strange, because that connector is still available in electronic industrial supply houses as a Mate-N-Lok product, and they are all white.  Almost all square and rectangular housings using those pins are still available; the only one not available is the curved turn signal connector.
« Reply #10 on: October 22, 2021, 10:35:08 AM »
I have a 68 column with the curved connector. I just noticed that a few days ago.
Thanks for the heads up on the Mate-N-Lock, midlife.
I've been driven crazy by the number of non-standard connectors used by Ford-- their efi stuff...gad!
So to see a standard used, I think I'm dreaming!
« Reply #11 on: October 22, 2021, 06:31:55 PM »
Wire loom and the related details are interesting IMHO since there was a number of suppliers and some of those subcontracted out to even smaller companies or even individuals to build so of them. Believe I've shared this before but in the late 60's early 70's while on vacation and traveling across the Calif/Nev desert we stoped to get gas and in the work space the employee (may have been the owner) was assembling electrical wire looms for Lincoln power seats.
With that yes have seen many discolored but many that were not. It's not like the location really got hot or any sun exposure so not as likely to discolor IMHO when compared to those located in other areas of the car but I think we all accept that plastic can discolor some just from age.
Found it difficult to find many pictures since these are, on an assembled cars), up and often out of view so good to have some pictures of disassembled cars from projects or yards.
Top two San Jose cars in low teens. Two lower Dearborn examples - left from a tilt
From the late 67 San Jose 390 fastback thread in the Unrestored Picture thread. Unfortunately very "bleached out" from the flash I was using :(
Lot of "rose" colored ones
All 67 San Jose examples.Some appear to be rose while bottom two are discolored. Uneven finishes
And a very nice very low mileage NJ built Mustang provided this picture
« Reply #12 on: October 22, 2021, 06:52:44 PM »
Mine looks like that last one.
Can I just use mine or is that unacceptable for concours?
« Reply #13 on: October 22, 2021, 07:20:32 PM »
For judging I can't see a situation where this would come under discussion and if it did what resources the judge and team would use other than memory. In that case the team would have to agree that it was the wrong one for the car and I can't see that happening. If you have a concern I would keep a picture of your original as well a print out of this discussion and include it in your detail/resource folder/binder that would be with you.
Can't recall a show where an electric plug came into question except on those that had been repaired or spliced over my 50 years of judging
Online midlife
« Reply #14 on: October 22, 2021, 10:44:02 PM »
I've refurbished just a tad over 100 1967's, and have at least 40 more in my stockpile.  I've never seen a true rose-colored 10 pin connector.  Some have a slight rose tint to it, but that is the reddest I've ever seen!  All that said, it doesn't mean it isn't original.  As J. Speegle says, so many folks were involved in manufacturing these harnesses.  I would believe, however, that the vendors that Ford used to distribute the connectors were fairly small, so to see one type of connector being so out of the normal color scheme seems odd to me.
As the pictures indicate, it is hard to see the connectors, unless one is upside down and viewing directly towards the steering column under the dash.  Most judging scenarios are unlikely to be that detailed.
