Author Topic: 67 Hard Fuel Line Connection  (Read 669 times)
Offline orgnl70
« on: November 19, 2021, 09:28:30 PM »
67 S Code. Holly Model 4150 4V Carb.
The hard fuel line from the fuel pump to the carb. stops short about an inch from the carb. inlet.  The end of the fuel line is raised. It looks as though a rubber hose is to be used. The carb. has a female thread.
Any suggestions? A picture would be helpful.
Thanks in advance
Re: 67 Hard Fuel Line Connection
« Reply #1 on: November 19, 2021, 10:04:14 PM »
filter?
« Reply #2 on: November 20, 2021, 12:39:42 AM »
Guess you missed or didn't check the Unrestored Picture Section of the site. Some forget that resource is there.
Check the S code fastback and picture posted as EC-2. Looks like aftermarket clamps but you will see the carb, and fuel line connection. With the filter
« Reply #3 on: November 20, 2021, 12:40:01 AM »
filter?
Correct. It needs a screw on Holley fuel filter. picture is of service replacement sold by NPD for 10.00.The assemblyline version is a little shorter very rare and expensive when you find one
