Author Topic: Shaker Vacuum Motor  (Read 1453 times)
Offline Wayne L
Shaker Vacuum Motor
« on: November 20, 2021, 02:27:05 PM »
Hello, I have a 428 SCJ built in Metuchen. The schedule build was 1/21/69 but actual build was 2/03/69. I am restoring it and the shaker vacuum motor assembly is completely bent up beyond identifying if it's a 3 bend or 4 bend, and there is no part # i can find on the part.
Does anyone know what vacuum assembly I need?
Thanks,Wayne
Offline 7Lscjracer
Re: Shaker Vacuum Motor
« Reply #1 on: November 20, 2021, 11:14:01 PM »
Scott Drake repops them and they're widely available
Here's one on CJ's site:
https://www.cjponyparts.com/cj-classics-shaker-vacuum-motor-1969-1970/p/3641QN/
Edit: That particular example is Dynacorn, Scott Drake is about 25 bucks more
« Last Edit: November 20, 2021, 11:16:38 PM by 7Lscjracer »
Bought May '81, sold Sept '20
Offline Wayne L
« Reply #2 on: November 20, 2021, 11:47:07 PM »
« Reply #3 on: November 21, 2021, 09:20:08 AM »
beware that vendor. check over on VMF for more info.
Offline Wayne L
« Reply #4 on: November 21, 2021, 11:30:52 AM »
Thanks, will do.
Wayne
Online K-HESS
« Reply #5 on: November 22, 2021, 12:48:22 PM »
If your trying to keep your car original you may want to see about finding a used one to have rebuilt. The original vacuum motor has a FoMoCo logo stamping on the one end and a date code stamping on the other. This one here I have pictured has a date code of 8 69.
Offline Wayne L
« Reply #6 on: November 22, 2021, 11:19:27 PM »
Who rebuilds them?
Thanks, Wayne
Offline 7Lscjracer
« Reply #7 on: November 23, 2021, 04:20:18 PM »
http://www.perogie.com/
Perogie Enterprises was rebuilding them 20 years ago, but I don't know if that's still the case today.
Is the guy with those skills still there?
If not, was he replaced by someone as capable?
You'll have to inquire.
« Reply #8 on: November 23, 2021, 04:53:38 PM »
As far as rebuilding these and other vacuum motors some rebuilders require two donors to make one rebuilt one due to the crimp method used to bond both ends together
Just something to check and consider
Guess in that case you might be able to use the dated half and a reproduction half if that fit your need
Offline Wayne L
« Reply #9 on: December 01, 2021, 11:01:39 PM »
Has been sent out for rebuild. Thanks for the help!
Wayne
Offline DougDyar
« Reply #10 on: December 02, 2021, 11:04:56 AM »
Can you please update this thread with who you sent it to and the job they did? Anyone searching for info on this process now or in the future would likely appreciate some more info. Thx!
0F02G203277
June 22, 1970 Dearborn BOSS 302
Offline Wayne L
« Reply #11 on: December 04, 2021, 01:25:25 AM »
Sent it to Perogie Enterprises in New Jersey. He said turn around time will be about a week and since I'm in California and it being the Holiday season I'm figuring I'll get it back around the first week in January.
I'll update how it turned out then.
Wayne
« Last Edit: December 04, 2021, 01:32:31 AM by Wayne L »
Offline Wayne L
« Reply #12 on: March 03, 2022, 11:06:56 PM »
UPDATE:
Sorry it took so long, I didn't get the part back until Feb. 10th and crazy at work so it got put off for a bit.
Sent it to Perogie Enterprises and it took alot longer then expected. Charged $85 to put a new diaphram in the original body.
Works great, but the solder job is a not pretty.
« Reply #13 on: March 03, 2022, 11:55:03 PM »
Has that been painted with silver paint ?
Offline Wayne L
« Reply #14 on: March 04, 2022, 12:13:34 AM »
Yes
