Author Topic: A method for removing Holley(R) bowl vent tubes  (Read 3416 times)
Offline Dan Case
« on: December 24, 2021, 01:01:18 PM »
It is not rare to have a Holley(R) 4150/4160 carburetor main body with a damaged bowl vent tube. Removing a damaged tube you plan on discarding is easy. Removing an excellent used vent tube without damaging it of the carburetor body is a little tougher. This might be done prior to refinishing the body or harvesting good parts from a low value core carburetor to repair or restore a rarer carburetor.
One method I have is to use an appropriate sized plastic screw anchor and screw to grip the tube softly from the inside and then pull it out by the screw head.
Dan
Online jwc66k
Re: A method for removing Holley(R) bowl vent tubes
« Reply #1 on: December 24, 2021, 02:20:31 PM »
I like it. Your method just solved my quandary on pulling a steel sleeve from a wooden frame.
« Reply #2 on: June 29, 2023, 11:21:56 AM »
This method also works for other tubes.
I replaced the tubes on my water pump by tight fitting a steel insert into the tube and then heating the body with an oxy/act torch.
A pipe wrench to loosen and curved jaw vice grips to remove.
Trying to grab the the tube without the insert results in a squished tube mess.
Offline Drew Pojedinec
« Reply #3 on: June 29, 2023, 05:24:18 PM »
I just hit the mainbody for 5 seconds with mapp gas and the vent tubes practically fall out.
Offline Dan Case
« Reply #4 on: June 30, 2023, 01:18:42 PM »
Neat.
Dan
