Author Topic: Trunk torsion bar question.  (Read 965 times)
Offline Texascobra
« on: January 12, 2022, 05:09:40 PM »
Should a Jan build 67GT500 with fiberglass trunk lid have the center support installed on the torsion bar as depicted? I have seen photos with and without. The steel framed trunk lids generally show them. If so, what should the finish and hardware be? FMR
65 427SC 4123
67 GT500 752 1/23/67
96 Cobra American Iron Racer
12 GT500 Daily Driver
Re: Trunk torsion bar question.
« Reply #1 on: January 12, 2022, 06:59:57 PM »
Steel/'glass yes.
All 'glass, no.
I wish the 'glass did so the torsion arm would work correctly.
Without the center support the end of the bar goes through an odd motion and tries to pop off the end cap. It can also make an ungodly sound (twang)!
Offline kkupec02
« Reply #2 on: January 13, 2022, 09:28:06 PM »
Mine is a 1/26/67 build GT500 and has the original center clip on it
1967 GT500 Built 1/26/67 #817
1967 Corvette Roadster
« Reply #3 on: January 13, 2022, 10:00:17 PM »
Steel/'glass yes.
All 'glass, no.
+1 The guiding factory is the type of lid the car has.
kkupec02's car #817 has the steel lined version
« Last Edit: January 15, 2022, 02:34:59 PM by J_Speegle »
Offline Texascobra
« Reply #4 on: January 15, 2022, 12:34:23 PM »
Thanks for the info. My car was built on 1/23 and should probably have the steel lined lid, but does not.
65 427SC 4123
« Reply #5 on: January 15, 2022, 01:06:56 PM »
Does your car have a hood with the steel innerstructure? I am curious about what Shelby vin number too.
Offline Texascobra
« Reply #6 on: January 16, 2022, 11:36:45 AM »
Number 752. The hood is after market. This car had been used as a race car earlier in life so many things were missing/wrong. You saw it in Mustang OK. Frank
65 427SC 4123
« Reply #7 on: January 16, 2022, 02:24:25 PM »
OK I remember now the lime gold car with the pleasant owner. Your car more typically came with the steel innerstructure hood and trunk lid . They were typically installed in pairs.  SA was transitioning to the all fiberglass parts and was completely done by about 600 units after yours. At least I have not found any later then that with out the benefit of knowing all completion dates. So your car could have possibly come with a all fiberglass hood and trunklid. The center bracket on the all fiberglass trunklid will make the torsion bar function better "IF" you can keep it from coming loose from the fiberglass. It will be a deduction in concours venues however because it never came that way from the factory. I would fix the hood and be done with the pair. The hood will always be a concours issue because the repro hood is noticeably made different then the original . You can possibly modify the repro hood to pass. Just some thoughts on the subject.
« Last Edit: January 16, 2022, 02:29:53 PM by Bob Gaines »
