Author Topic: WTB 68 J code smog system  (Read 669 times)
« on: January 20, 2022, 09:14:04 PM »
WTB 1968 J code smog system. I have the pump mount but need everything else.
Offline preaction
Re: WTB 68 J code smog system
« Reply #1 on: January 20, 2022, 09:26:59 PM »
Marty, WCCC might be worth a call.
« Reply #2 on: January 21, 2022, 12:53:40 AM »
Most parts are out of stock at WCCC.
Offline tim_morrison82
    • Click Here for My Project
« Reply #3 on: January 21, 2022, 03:22:59 AM »
Marty, can you send me part numbers? I'll take a look at my stocks.
« Reply #4 on: January 21, 2022, 10:05:17 AM »
Pully on Pump C8AE-9C480-A Pump has fan under the pulley.
Pump hose C8OE-9F287-A
RH hose C8OE-9B466-A or -E
LH hose C8OE-9C433-C
Air logs were the same RH and LH and had crimped ends.
Check valves had 5/8 nipples
That is a start
Here is a picture of the parts
« Last Edit: January 21, 2022, 10:56:08 PM by ruppstang »
Offline Mike_Senar
« Reply #5 on: January 22, 2022, 12:04:28 PM »
  Hello,
  Are those smog tubes the 289 version.   The ends of the correct tubes are not capped off, they are pinched...?!
        Mike
« Reply #6 on: January 22, 2022, 02:56:12 PM »
  Hello,
        Mike
Mike you are correct those pictured are the 66-67 version. As I said in my text above they are crimped. Glad you caught that.
« Reply #7 on: January 22, 2022, 02:57:03 PM »
Thanks everyone I located a system.
